Timing cover question
1967DartGT
Livingston, MT
Is there a difference in timing covers between early LA engines with the cast iron water pump, and later LA engines with the aluminum water pump?
Be careful, I think there is a thread in the smallblock section outlining all the different timing covers and the differences. Search for it. I know it's in there and it's informative.
The water pump inlet will block the timing mark. You`ll need to use the proper pump and radiator to orient the water inlets.
Yeah, my water pump inlet blocks the timimg mark. It's a pain to time it. Trial and error.
