1. WRB426
    WRB426 Insane 4 Mopars FABO Gold Member
    2,237
    173
    Apr 20, 2011
    MA
    Local Time:
    2:42 AM
    What are the differences on small block timing covers?
    I need one for a 360. Not sure if any one will work and what part # I should look for.
    I'll be running the Edelbrock water pump and 67 and up alt bracket.
  2. 67Dart273
    67Dart273 Well-Known Member
    38,642
    6247
    Oct 14, 2010
    Idaho
    Local Time:
    11:42 PM
    Negating late LA EFI or Magnum, "about 70?" Ma went to the longer aluminum pmp with the timing marks on driver side, lower hose on pass side
    Previous, the older short pump had the timing marks and lower hose reversed from above.
  3. WRB426
    2,237
    173
    Apr 20, 2011
    MA
    Local Time:
    2:42 AM
    Ok thanks. I'll look for a driver's side timing mark one.
