Timing way off..help.
Electrical and Ignition
  1. Originalowner73 340duster
    Originalowner73 340duster Well-Known Member
    514
    52
    Jan 18, 2018
    New York
    Local Time:
    2:37 AM
    My car was running mint...sat few days and is missing// not revving up good almost like only half firein...all plugs getting spark but with inline tester on light is not consant when Rev..can still see it blink/ coil getting good spark.. pick-up is good and correct gap. ..but I'm checking the timing and it's like few inches from where mark is...how could it get so far off and can you even adjust distributor that much??.. or maybe something eles happened to it..any help.sorry if seems dumb..I'm lost .. checked all I could think of..any suggestions would help...I'm lost now...lol
  2. Jet
    Jet Well-Known Member
    54
    73
    Dec 11, 2015
    Ocala
    Local Time:
    2:37 AM
    It may have jump a tooth on the timing chain.
  3. spl440
    spl440 Everybody's Fool FABO Gold Member
    1,463
    1638
    Feb 2, 2011
    Hot Springs AR
    Local Time:
    1:37 AM
    What engine, how many miles on motor, what type of ignition system? You know,the common stuff we always need to help trouble shoot.
  4. Alaskan_TA
    Alaskan_TA Well-Known Member
    5,697
    4006
    Nov 12, 2004
    PA
    Local Time:
    2:37 AM
    Timing chains can jump.
    Key-ways can shear.
    Remove the distributor cap so you can watch the rotor.
    Turn the crankshaft bolt back & forth by hand, try both directions.
    The rotor should start turning in unison right away.
    If not, time to take the front of the engine apart for a look.
  5. mopowers
    mopowers Well-Known Member
    4,842
    1938
    Feb 15, 2006
    West Sacramento, CA
    Local Time:
    11:37 PM
    If you're using a mopar electronic distributor, check the roll pin that holds the reluctor wheel. I've had one slip out and allow the reluctor to move, throwing the timing off.
    • Like Like x 1
    • Originalowner73 340duster
      514
      52
      Jan 18, 2018
      New York
      Local Time:
      2:37 AM
      Everything is spinning in sync...has rebuilt late 72 340 I think motor is stock possible can, headers , running thermoquad..stock ignition with crome box..only 20 k on motor..was running fine.. thought if it jumped a tooth I would have heard it..motor idles great..lol
    • MoparLeo
      MoparLeo NRA PATRON LEVEL LIFE MEMBER FABO Gold Member
      536
      331
      Feb 10, 2016
      Moreno Valley, Cal. So. Cal.
      Local Time:
      11:37 PM
      Do the basic mechanical check to verify # 1 cylinder TDC. Then check timing mark on balancer. Sounds like more than one problem.
      514
      52
      Jan 18, 2018
      New York
      Local Time:
      2:37 AM
      Yah..I took out pickup and readjust gap..now I'm not getting spark out of the coil..all wires look good..been messing with this thing for a week ..now it's worse.. frustrated..beer time..
      • Agree Agree x 1
        514
        52
        Jan 18, 2018
        New York
        Local Time:
        2:37 AM
        Any ideas to get new crome ignition box??? Or should I just get another brand/ does it matter??
        514
        52
        Jan 18, 2018
        New York
        Local Time:
        2:37 AM
        And I do have spark at coil wire but it's very small
      • MoparLeo
        536
        331
        Feb 10, 2016
        Local Time:
        11:37 PM
        Do you have a friend with a small block 318,340,360 with electronic ignition ? Just swap the Box and test, also the distributor. Easy to swap back and forth and can save a lot of time. If your ignition parts are old why not just replace them with new. The parts including the distributor are pretty cheap everywhere.
      • xLURKxDOGx
        xLURKxDOGx "An angel fat, at satan's feast" FABO Gold Member
        3,923
        1297
        Dec 27, 2013
        PHX
        Local Time:
        11:37 PM
        Factory distributor?
        Jake
        514
        52
        Jan 18, 2018
        New York
        Local Time:
        2:37 AM
        Yes..not useing vacuum advance tho
      • xLURKxDOGx
        3,923
        1297
        Dec 27, 2013
        PHX
        Local Time:
        11:37 PM
        Ok, I was just curious because I have a pertronix billet unit and the rotor top is mated to the shaft by some sort of rivet, and I had taken it to have my transmission rebuilt on my 63 and they let the engine hit the firewall breaking the cap and loosening the rivet to point where it was moving all over the place, it took 3 stops of adjusting the distributor to figure it out.
        Jake
      • 4spdragtop
        4spdragtop FABO Gold Member FABO Gold Member
        29,369
        9674
        Aug 28, 2009
        Wasting time here
        Local Time:
        1:37 AM
        Ignition box, is that voltage regulator? Get one from dealership.
        514
        52
        Jan 18, 2018
        New York
        Local Time:
        2:37 AM
        Dealership don't have..and keep getting told to go to Westbury..but no answer on phone or email..any one know where to get it on long island??
        514
        52
        Jan 18, 2018
        New York
        Local Time:
        2:37 AM
        Ok not the ignition module or coil..ballsast has good resistance reading..but I noticed I have up and down movement on my pickup..the plate is tight but is the play on top normal??
      • TrailBeast
        TrailBeast AKA Mopars4us on Youtube
        21,406
        8998
        Mar 11, 2011
        Arizona
        Local Time:
        11:37 PM
        Yep, some up and down play is normal between the lower and upper sections of the shaft.
        Just off the top this sounds like a bad ignition box. (if we are ignoring a possible chain jump for the moment)
        Disconnect the plug that goes to the distributor and with the ignition on touch the exposed metal bullet on the harness end to the engine block to ground it.
        Each time you touch it to ground you should get a good spark.
        514
        52
        Jan 18, 2018
        New York
        Local Time:
        2:37 AM
        I only get a tiny spark every so often..not consistent at all when I jump at coil wire..car is having hard time starting now also and I tried swapping ignition module,coil..no change
        514
        52
        Jan 18, 2018
        New York
        Local Time:
        2:37 AM
        Also if the chain jumped wouldn't I have herd something..and got problem while driving..was fine when I shut off then boom .lol
        • Disagree Disagree x 1
        • TrailBeast
          21,406
          8998
          Mar 11, 2011
          Arizona
          Local Time:
          11:37 PM
          A new distributor pickup is cheap enough.
          (you did say you checked everything else) and that when you took it out to adjust it you didn't have spark.
        • TrailBeast
          21,406
          8998
          Mar 11, 2011
          Arizona
          Local Time:
          11:37 PM
          Most of the time a chain jumps it is on shutdown and you won't hear anything.
          Then the next time you go to start it is when most find out.
          Make sure you rotor is on good and solid and check for slack in the chain by turning the motor back and forth a little as was suggested above.
          • Agree Agree x 1
            514
            52
            Jan 18, 2018
            New York
            Local Time:
            2:37 AM
            I found a whole new complete distributor shaft and orange ignition box with wires for 150..think of upgrading..
            514
            52
            Jan 18, 2018
            New York
            Local Time:
            2:37 AM
            When I first checked I had light constant spark from coil wire now it's just every once In awhile but still light spark...and doesn't seem to have play from rotating front to distributor shaft
            514
            52
            Jan 18, 2018
            New York
            Local Time:
            2:37 AM
            And motor Should be 20k miles new..did sit awhile tho
