If you're running a correctly matched rim size, you can find the tire pressure your combo wants in order to have a full contact patch by using chalk.
Scruff about an inch wide mark of some chalk across the tread from inside to outside on the tire. Drive in a straight line for about 40 feet, and see how the chalk has worn across the tread. If only the middle, then lower pressure and repeat. If only on the outside edges, then add air. If only +- 75% or 80% of the tread including the middle, reduce air pressure until it wears evenly across the tread. The maximum pressure recommended on the side of the tire is
It's all about the shape of the tire's bulge on the ground contact given the weight that's currently on a given tire.
Keep this in mind too. I run 18psi on my Nitto 275/60-15's for maximum contact patch i.e traction, however I increase the pressure up to 22 psi for road trips to account for the car being heavier (still full contact patch), and to allow the sidewalls to be stiffer for cornering.
Same thing for my 3/4 ton truck. With nothing in the bed, the rear tires like 42 psi, while the fronts like 45 psi. with 500 pounds in the bed, the rears need 45 too. The tires wear extremely evenly when I adjust their pressures this way.
Almost everyone uses too high of tire pressure when going by what the sidewall pressure recommends at maximum load, because their car puts no where near that weight on their tires. Their tires wear out in the middle in most cases. In my case, my truck tires sidewall reads 80 psi for 3970 lbs load max. The entire truck only weighs 7500 lbs. unloaded, and ready to travel.
