Tools Explained
Shop, Garage and Tools
  1. Trevor B
    Trevor B FABO Gold Member FABO Gold Member
    471
    200
    Nov 2, 2014
    Novato, CA
    Local Time:
    7:56 PM
    TOOLS EXPLAINED
    DRILL PRESS : A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
    WIRE WHEEL : Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh*t.' Also used to dust work area with liberal sprinkling of tiny, wiry, wires, which you only find much later sticking out of your scalp as you cut your finger washing your hair!
    DROP SAW : A portable cutting tool used to make studs too short.
    PLIERS : Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
    BELT SANDER : An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
    HACKSAW : One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
    VISE-GRIPS : Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
    OXYACETYLENE TORCH : Used almost entirely for lighting on fire various flammable objects in your shop. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
    TABLE SAW : A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
    HYDRAULIC FLOOR JACK : Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
    BAND SAW : A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
    TWO-TON ENGINE HOIST : A tool for testing the maximum tensile strength of everything you forgot to disconnect.
    PHILLIPS SCREWDRIVER : Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
    STRAIGHT SCREWDRIVER : A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms. Also known as the shop beer bottle opener.
    PRY BAR : A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER : A tool used to make hoses too short.
    HAMMER : Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
    UTILITY KNIFE : Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
    ADJUSTABLE WRENCH: aka "Another hammer", aka "the Swedish Nut Lathe", aka "Crescent Wrench". Commonly used as a one size fits all wrench, usually results in rounding off nut heads before the use of pliers. Will randomly adjust size between bolts, resulting in busted buckles, curse words, and multiple threats to any inanimate objects within the immediate vicinity.
    Son of a bitch TOOL : Any handy tool that you grab and throw across the garage while yelling 'Son of a b*tch' at the top of your lungs. It is also, most often, the next tool that you will need.
    • Like Like x 15
    • Thanks! Thanks! x 3
    • Agree Agree x 1
    • Treblig
      Treblig Well-Known Member
      5,948
      3172
      Oct 5, 2013
      South Texas
      Local Time:
      9:56 PM
      AHhhh! The "son of a bitch tool" (when thrown at high speeds) will frequently bounce off of hard object and come back only to hit you in the ankle, ribs or some other vulnerable place!:mad::poke:
      • Agree Agree x 4
      • Like Like x 2
      • 69conv
        69conv error 401 FABO Gold Member
        3,370
        4444
        Jan 27, 2013
        Motor City
        Local Time:
        9:56 PM
        Can I add the extension swivel necessary in converting rotational torque into knuckle busting lateral force when least expected. Available in 3 sizes!
        • Like Like x 3
        • Agree Agree x 3
        • krazykuda
          krazykuda Well-Known Member FABO Gold Member How-To Section Editor
          52,810
          17800
          Aug 20, 2007
          Orland Park, IL
          Local Time:
          9:56 PM
          • Like Like x 3
          • Agree Agree x 2
          • 69conv
            3,370
            4444
            Jan 27, 2013
            Motor City
            Local Time:
            9:56 PM
            The random tool cloaking device is produced when a tool box is in the proximity of and automobile and results in tools temporarily disappearing from where you put them down. This field becomes stronger the longer you work on the car, the later at night and can substantially strengthened with the aid of alcohol.
            • Like Like x 3
            • Agree Agree x 2
            • Lord Sparky
              Lord Sparky Well-Known Member
              241
              174
              Dec 2, 2019
              Carlsbad, California
              Local Time:
              7:56 PM
              Hilarious! Got a good belly laugh!
              • Agree Agree x 2
              • Lord Sparky
                241
                174
                Dec 2, 2019
                Local Time:
                7:56 PM
                I once used the Son Of A Bitch tool to smash the hood of my 1969 Dodge Dart. This was back in the '70s before they were beloved relics.
                • Like Like x 1
                • rbkt65
                  rbkt65 FABO Gold Member FABO Gold Member
                  498
                  252
                  Dec 25, 2017
                  illinois
                  Local Time:
                  9:56 PM
                  one more sob tool: battery operated drill/grinder/sawzall. when picked to use battery is always dead/almost dead/or son has it.
                  • Like Like x 2
                  • 69conv
                    3,370
                    4444
                    Jan 27, 2013
                    Motor City
                    Local Time:
                    9:56 PM
                    I have 3 sons so I tripled my odds!
                    • Like Like x 2
                    • barbee6043
                      barbee6043 barbee 6043 FABO Gold Member
                      12,495
                      5132
                      Jul 20, 2008
                      Shepherd, Texas ( SE Tx)
                      Local Time:
                      9:56 PM
                      Tool: Pump up herbicide sprayer, can be the 1 gal or 2 gal , either works to spry diesel on the huge brush piles loaded with a few old tires for extra heat. As you spray the wind blows some back on your shirt, it is winter so it is flannel. So you light it off and go back to old car work. Cutting of some sheet metal with the cut off wheel, no doubt, sends sparks back on the shirt which just yesterday got a good dose of diesel spray. Poof!!! Course, you are doing all this outside in the wind. Slapping it our with your cap just fans it more. Burn. Burn. Burn. Maybe rollover on the et ground?
                      Who need those arm hairs, eyebrows, etc anyway??????
                      • Like Like x 2
                      • Garrett Ellison
                        Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
                        2,689
                        2110
                        Jan 1, 2018
                        Southwest VA
                        Local Time:
                        10:56 PM
                        From the files of Rick "Super Hunky" Sieman; "Trouble light: A tool used to consume 75 and and 100 watt light bulbs at the same frequency as a 115mm howitzer would consume shells at the Battle of the Bulge. More often dark than light, the name is somewhat misleading."
                        • Like Like x 4
                        • Agree Agree x 1
                        • thesiren74
                          thesiren74 Well-Known Member
                          1,233
                          814
                          Feb 23, 2014
                          kenosha,wi
                          Local Time:
                          9:56 PM
                          Awesome!!
                        • trapster
                          trapster Well-Known Member
                          2,587
                          220
                          Feb 19, 2009
                          Central Florida
                          Local Time:
                          10:56 PM
                          Breaker Bar : self explanatory, Used to break off that stud that has a stuck nut on it.
                          • Like Like x 3
                          • sabre67
                            sabre67 FABO Gold Member FABO Gold Member
                            711
                            162
                            Jan 9, 2015
                            British Columbia,Canada
                            Local Time:
                            7:56 PM
                            the son of a bitch tool usually has blood on it
                            • Agree Agree x 2
                            • Like Like x 1
                            • Red63440
                              Red63440 Olddawg
                              527
                              521
                              Dec 13, 2011
                              Batavia, NY
                              Local Time:
                              10:56 PM
                              I had a table saw that brought tears to my eyes........two times. The first time it was because it kicked back a burl from a tree on Thanksgiving morning, I looked like WC Fields at the dinner table. Second time it kicked back a 1"x 6" piece of oak which hit me so hard it broke my upper plate in half.
                            • Lefty71
                              Lefty71 Well-Known Member
                              244
                              178
                              Nov 7, 2013
                              Ohio
                              Local Time:
                              10:56 PM
                              Wow!! Thats a name from the past..... makes me want to go out and see if the old CZ will fire up. :thankyou:
                              • Like Like x 2
                              • dartfreak75
                                dartfreak75 Restore it, Dont part it! FABO Gold Member
                                7,476
                                5233
                                Aug 10, 2011
                                Virginia
                                Local Time:
                                10:56 PM
                                Hahaha I got a good laugh at this thank you!
                                • Agree Agree x 1
                                • dartfreak75
                                  7,476
                                  5233
                                  Aug 10, 2011
                                  Virginia
                                  Local Time:
                                  10:56 PM
                                  The hacksaw one really cracked me up! Because it's so damn true haha
                                  • Agree Agree x 1
                                  • pishta
                                    pishta I know I'm right....
                                    17,304
                                    6914
                                    Oct 13, 2004
                                    Tustin, CA
                                    Local Time:
                                    7:56 PM
                                    Plasma cutter: Perfect tool to cause blindness, or to use in a completely blind manner because you cant see your guide lines. Also used to ignite whatever is under the workpiece as well as create a cut that is so gnarly as to guarantee more time on a grinder than would just using a cut off wheel in the first place.
                                    • Agree Agree x 2
                                    • Stephen Morrow
                                      Stephen Morrow New Member
                                      2
                                      1
                                      Mar 9, 2020
                                      Canada
                                      Local Time:
                                      10:56 AM
                                      HAHAH! I died!
                                      • Agree Agree x 1
                                      • Garrett Ellison
                                        2,689
                                        2110
                                        Jan 1, 2018
                                        Southwest VA
                                        Local Time:
                                        10:56 PM
                                        FWIW, I have a friend with an eight inch wire wheel brush mounted to an old washing machine capacitor start, capacitor run motor with no guard of any kind. Just a big wire wheel of death hanging off the end of the bench spinning at very high rpm. Probably the single most dangerous power driven anything I have ever ran, I haven't been able to make it stall or even slow down no matter what I pressed into it until sparks and brush bristles were flying. I call it "No Conscience", one slip up and I'm pretty sure somebody's going to the nearest ER.
                                        • Agree Agree x 1
                                        • SpeedThrills
                                          SpeedThrills FABO Gold Member FABO Gold Member
                                          1,602
                                          368
                                          Jun 3, 2008
                                          Very South Jersey
                                          Local Time:
                                          10:56 PM
                                          Did you ever whack something real good with a rawhide mallet only to have it bounce straight back and hit you in the nose? I ah, may have done that...
                                          • Like Like x 1
                                          • Treblig
                                            5,948
                                            3172
                                            Oct 5, 2013
                                            South Texas
                                            Local Time:
                                            9:56 PM
                                            Ever sneezed laying face up under a car and slap your head against the undercarriage???/ DON'T LIE!!!:poke:
                                            • Like Like x 1
                                            • Righty Tighty
                                              Righty Tighty Well-Known Member
                                              425
                                              267
                                              Aug 16, 2019
                                              Sahuarita, AZ
                                              Local Time:
                                              7:56 PM
                                              Looks like I've been using these correctly all along! Thanks for this!
                                              • Like Like x 1
