Torque Converter TF904 for nitrous
Michel
Active Member
Bento Gonçalves
Hi Guys
my engine small block 318 with 300/350cv ..'ll throw 100/150 nitrous .. I need a torque converter with Anti-Plate Ballooning ?? is required???
Thanks
Check out FTI torque converters for mopars. Either their site or Jegs carries them. Even ebay now has them. I got one for my 727 in 9.5 inch and 3400-3600 stall. They are efficient @ low speeds and are rated to 700+ horsepower I believe. Also anti ballooning standard! So its features are impressive. They are a little spendy @ $600+ but you get what you pay for! Ohh also they have 7/16 mounting pads for stronger fastener strength!
:glasses7:
:glasses7:
That's cheap, for a good converter..( to the o.p. ..Yes ,buy a good converter.. )Edge/ Turbo Action/ Continental ,off the cuff.. Others ,will come along & suggest.. Be patient,on responses please.. Be honest on your expectations ,& possible future modifications.to us,& to the torque converter company you choose..)
thanks guys.. I will contact the TFI ...
I found very interesting the TCI Super StreetFighter 142322 .. has Anti-Ballooning Plate .. 10 inch and 3600 stall
TCI recommend ?? has anyone had problem or heard speak ill of them ??
http://www.summitracing.com/int/parts/tci-142322
my configuration: cam engle 282/282 (244/244@0.50"), 107 lob, .533 lift .. 2800 to 6500 rpm.. intake Mopar M1 single plane, 9.5:1 compression, 4:10 gear
Negatively, no.. on TCI out of the box, period. 20 years ago, hell yes.. Now garbage box lunch, your stuck with it. ( Why I asked for combination specs, you can't buy a good converter out of the box, especially Mopar.. Buy a custom one, been here & done that.
:glasses7:
friend this is for TorqueFlite 27 spline ?? my transmission is 1976
http://www.jegs.com/i/FTI+Transmissions+&+Converters/107/SRC00826/10002/-1???
You will not get a GOOD converter for your setup off the shelf. It will have to be custom made FOR YOUR APPLICATION. Contact any of the converter builders others have mentioned in this post and your other post, with the specifications of your engine combo, tire size, diff. ratio.
