Hello all! I'm having troubles with getting my torsion bar adjusting bolt to come lose, there's no bar in the lower arm at the moment and i need to lower the bolt some to get the torsion bar to insert where it goes. Ive tried penetration lubes but not heat. I just replaced all my balljoints and torqued and pinned them so I dont wanna remove it to lower the control arm and make the bar fit. I'm also likely going to want to lower the car a bit once it's together so they need to move.
That said, i get a minor turn loosening it with loud crack sounds from pressure im using, i tried impact and it started mucking up my control arm so I stopped with that. Is there any suggestions from vets with these bolts? I see I can buy replacements so worst come to worst, i can cut them out and replace but trying to get this together! =) would simple heat from torch and more lube do the trick? That and max pressure is my next hope, with hope not to break them.
Any tips are apprecaited!
