jeffnmo
Just another Mopar Maniac
Hey all, I've been trying to remove the drivers side torsion bar for an hour, passengers side came out fine, can I cut the bar with a sawzall?
Thanks Jeff
Thanks Jeff
Back out the pivot bolt... Unbolt the control arm and the strut rod... Remove the wire spring clip behind rear of torsion bar.
Pry the control arm back with long pry bar between k-member and control arm. That will push the torsion bar out of the crossmember.
Then whack the control arm off the front of T bar while it is dangling .
Hope this helps.
MAKE SURE EVERYTHING IS UNLOADED AS FAR AS TORQUE.... AND IN THE AIR!
Thanks guys, There is no load on the bar, I made my own removal tool and it should slide out, the passengers side did. I may try what mbaird said but I really don't want to loosen up what I don't need to, or get out the side grinder like hemi71x said.
Jeff
mbaird, they both slid back and are clocked properly, I forgot to grease the drivers side bar when I did the bushings and it rusted just enough to cause me fits, if the Dart was driven every day maybe it wouldn't have been so bad, its a car, weirder things have happened. About the alignment, it drove real good, I took my hands off the wheel and it stayed strait, I just thought an alignment would be a good idea, if there is no need that would be great, Money is very tight around here.
Thanks again guys Jeff
Here's what I did with a stuck one, backed off the tensioner all the way, on jack stands of course, then put a 24" pipe wrench on the bar worked back and forth a bit and was able to beat it out with a mallet hitting the side of the pipe wrench.
Its already out and the new ones in, all the bushings were done awhile back but I couldn't afford the bigger bars at the time. Ride hight is set and it drives nice, getting an alignment Monday. Thanks for all the help from everyone.
Jeff
