torsion bar rubber
iggys68dart
jacksonville fla
i am looking to fix front end of my dart and drivers side rubbr piece wich i believe is boot is ripped it would be located at the front of car and held on by washer and nut am i refering to part correctly and how hard is it to change thanks
I believe the part you are referring to is the strut rod and it's purpose is to locate the lower control arm and keep it in place. I just rebuilt my front end and am pretty sure that the lower control arm needs to be at least partially removed to get the strut rod out.
Torsion bars are located under the car about where you sit, with one end in your lower control arm and the other in your sub frame. They are held in by small wire type clips.
the part i was trying to describe is about 3 inches across and both are at the front of car on long pieces of rods please clarify
