Rustypeashooter
Member
sorry this is my first mopar 75 duster, I was wondering if you can adjust the torsion bars on the car like a truck? Can you lift or lower the front end or does mess all the geometry up?
Thanks, I kinda wanna lift it but not sure how much lift I could get out of itId suggest a search of the forum on this
Quick answer is yes you can, adjuster is under the lower control arm, and yes...it will mess with the steering alignment/geometry
I went a little on the high side to keep my cheap headers off the ground and I like the look.
Was thinking of making like a gasser style duster but I guess the leaf spring gasser front suspension would be easier after reading some of the threads
5 years and have never touched my headers on the ground once...I did this as well. Only an inch and a half and I was good.
You have to take the shocks off if you go to high LOLDo not jack them up that high
You got a pic?I went a little on the high side to keep my cheap headers off the ground and I like the look.
LOL it looks like not. I'm sure there's pictures of my car on other parts of the Forum like massive reconfiguration on the racing part. I tried my phone is just not cooperating right now with pictures..You got a pic?
You wont get them high enough for a gasser look.You got a pic?
Some people just wanna be different man, I don’t wanna be like every other dusterMaybe it's just me, but I don't believe I could sleep at night if I made a Duster look like a Gasser, just too period incorrect. That's more of an early seventies Pro-Stock piece... But a mid sixties to 1971 Swept-Line short box truck or home made panel van based on one (and it already has a straight axle under it), I could get into that!
Two thoughts.Some people just wanna be different man, I don’t wanna be like every other duster
Two thoughts.
1: it’s your car.
2: it’s a 1975 Duster, not a 70 hemi cuda.
Both equal the same thing, do what you want to it. Ignore the naysayers.
That said, gasser styling one of these has been done before and usually with terrible driveability. Be prepared to re-engineer at lot of structural support on the car. Sub frame connectors and front frame rails especially
There was a guy who did it with a 74 Dart Swinger a few years back on here. It’s been listed for sale off and on since as it was nearly unsafe to drive or so he said. Getting steering geometry correct and safe to drive is a challenge for mostThanks....I’ve built a lot of cars jeeps trucks rock crawlers etc....so I don’t mind fab work....I just wondered if anyone else had done it already to get an idea
You’re still gonna have to get the geometry correct for the car. Keep in mind, gassers were designed for weight transfer for drag racing. Not for the street. The High front roll center, the Ackerman and scrub radius. Plus more all comes into play to make it safe to drive on the street. Do your homework and math and make sure you do it right. And you’ll be just fineYeah I was thinking about maybe a straight axle coil spring front with a 4 link set up like on a Jeep xj and making a track bar, or even using the front long arm kit they use on a xj long arm lift kit
