Toyota spindles?
Early A-Body Discussions
  1. Cuda416
    Cuda416 FABO Gold Member FABO Gold Member
    1,662
    1219
    Jun 12, 2014
    South, TX
    Local Time:
    5:03 AM
    Someone told me certain toyota spindles can be used for front end disc brake conversions on A-Bodies. Sounds a bit bizarre, but I've seen weirder things before. Is this actually a thing?
  2. hemi71x
    hemi71x FABO Gold Member FABO Gold Member
    6,064
    2719
    Dec 22, 2009
    Rancho Cordova, CA
    Local Time:
    4:03 AM
    Someones been telling you a load of s#*t.
    • Like Like x 1
    • Cuda416
      1,662
      1219
      Jun 12, 2014
      South, TX
      Local Time:
      5:03 AM
      Ha, that's pretty much what I figured. He wasn't trying to sell me anything, just give me a pile of stuff.
    • Jim Lusk
      Jim Lusk Well-Known Member
      4,915
      1235
      Mar 8, 2006
      Fresno, CA
      Local Time:
      4:03 AM
      If there are spindles that could fit I wouldn't have any idea what they were. Also, the bolt pattern for the wheels would be wrong. Find some Mopar brakes.
    • mvh
      mvh FABO Gold Member FABO Gold Member
      1,671
      399
      Dec 17, 2007
      Menlo Park, CA
      Local Time:
      4:03 AM
      Just to start with, it would have to be a rear wheel drive Toyota. What would that be? A truck? I think he was zooming you.
      • Like Like x 1
      • hemitheus
        hemitheus 19? Plymouth Scampenstein
        3,167
        73
        Oct 7, 2010
        Taylor, MI
        Local Time:
        6:03 AM
        giant crock of horse puckey
        • Like Like x 1
        • JDMopar
          JDMopar Well-Known Member
          4,039
          2996
          Jan 19, 2012
          Candler, NC/Myrtle Beach, SC
          Local Time:
          7:03 AM
          One of the disc brake conversion kits uses Yota rotors on custom hubs. Don’t remember which one, but using the rotors is a thing.
        • SIX225
          SIX225 Well-Known Member
          144
          71
          Jan 31, 2016
          Illinois
          Local Time:
          6:03 AM
          I believe Scarebird uses redrilled Toyota Previa (minivan) rotors with the original drum hubs with their conversion.
          • Agree Agree x 1
          • Cuda416
            1,662
            1219
            Jun 12, 2014
            South, TX
            Local Time:
            5:03 AM
            Looking a the scarebird stuff has me wondering of I misunderstood and what was described was in fact the hub being a toyo part and not the spindles. makes much more sense.
          • 69_340_GTS
            69_340_GTS Well-Known Member
            4,466
            2612
            Jul 11, 2014
            Torrington, CT
            Local Time:
            7:03 AM
            Not really. Loads of cars, even foreign ones used 5x4.50" (114.3mm). Some were 5x100mm, which is very close to the 4".
          • j par
            j par Well-hung Member
            27,858
            15291
            Jul 2, 2014
            Portland Oregon
            Local Time:
            4:03 AM
            What do spindles have to do with bolt patterns?
          • Cuda416
            1,662
            1219
            Jun 12, 2014
            South, TX
            Local Time:
            5:03 AM
            Toyota spindles?
            • Like Like x 1
            • Garys72Duster
              Garys72Duster Well-Known Member
              550
              313
              Apr 23, 2017
              Golden, Co
              Local Time:
              5:03 AM
              That's right. I have used Toyota wheels on my Plymouth. Some Ford wheels also work. 5 on 4.5 " bolt pattern. I also have a Powerglide tranny and a Ford 9 inch rear end in my race only 68 Valiant. Seems wrong, but whatever works! LOL
            • jedrattle
              jedrattle Well-Known Member
              327
              91
              Jul 31, 2005
              Riverside ca
              Local Time:
              6:03 AM
              '79-'94 2wd pickups
              Rwd Celica's
              All have the same bolt pattern (5x4.5). Those are UCA/LCA style suspensions. These are the only possibilities. I have heard that Toyota spindle rumor before. The only to know is to measure them and compare to the mopar
            • inertia
              inertia Well-Known Member
              3,481
              762
              Feb 4, 2011
              Victoria B.C. Canada
              Local Time:
              4:03 AM
              Not Celica, they're 4 bolt, but perhaps Cressida.
            • BillGrissom
              BillGrissom Well-Known Member
              7,542
              469
              May 10, 2009
              Sacramento
              Local Time:
              4:03 AM
              Scarebird's kits keep the Mopar spindles and hubs. They give you calipers and rotors from common Chevy, Toyota, and such, plus brackets to mount the calipers (main item).
              Hardly an expert, but Mopar spindles look a bit unique in that they don't have a steering arm. That is part of the lower-ball joint. I think most other U.S. RWD cars have an arm integral w/ the spindle, as do my 1980's M-B cars. There are so many things that would have to be correct for a Toyota spindle to work that it seems unlikely. Also, many models of Toyota and most likely those spindles vary, so we don't even know what the guy was talking about.
              • Thanks! Thanks! x 1
              • TheGrateRonzini
                TheGrateRonzini FABO Gold Member FABO Gold Member
                952
                811
                Oct 25, 2017
                Western New York
                Local Time:
                7:03 AM
              • Cuda416
                1,662
                1219
                Jun 12, 2014
                South, TX
                Local Time:
                5:03 AM
                Although interesting from a "Hold my beer" point of view, it's a bit beyond our ability at this point :)
