Professor Fate
Push the button, Max...
I have the usual problem with the carb going dry after a few days (no leaks, all the usual culprits have been addressed), and while it doesn't bother me too much, it bugs the wife... and so I'm pondering ways to make it better. Yes, non-ethanol gas goes a long way to not having this issue, but it's not always an option with a daily and potential long-distance cruiser.
So my thinking is this:
Barring any leaks, the only way to dry out the carb is by evaporation. Evaporation can only occur when open to the atmosphere- it won't happen in a closed system. Later Lean Burn and ESA feedback ThernoQuads addressed this by adding a bowl vent solenoid valve wired to Ign Run. Previous manual valves were open at rest and allowed vapors to escape.
I've got my current carb pretty dialed in and running like a champ, so I don't really want to swap carbs at this point, so my question becomes this:
Has anyone tried hooking up an external 12v NC valve to the vent fitting, wiring it to IGN run? If so, did it prove to be of any benefit? Did it aid in starting after extended periods? Should I just forget about it and go have a beer?
