Transgo TF-2 Instructions
swifty
Bismarck, ND
I am rebuilding by 727 which had an existing shift kit.
Time for 727 rebuild.
I think it is a TF-2, was done before I owned car. The line pressure spring is blue. There is a wall drilled out in a pocket, check ball removed and plug in case. Does anyone have a set of instructions they can send me? I had another member send me some, but unfortunately I can not read them.
Here you go!
Thanks a lot! Hope to figure out what I have. It worked pretty well pre-teardown but want to check it over before it goes back together.
Keep in mind the instructions have changed slightly over time.
I know the earlier TF-2 used different springs on PR valve. Does the B&M kit use a blue spring on the PR valve? Mine has a single spring with no shims. I will check the length of TV valve to see if it has been ground. I will also check spring.
As I said it worked ok pre-teardown but had some issues when opened up. If it was as stock trans it would be easy to figure out.
