transmission cooler AN size
soaringcowman
what size AN fitting is the transmission cooler fittings on the transmission? I know the hose is 6AN.
adam
The case threads are 1/8 NPT but the tube is 5/16" O.D. which would make it a 5 AN size. Good luck finding that one. If you can find a 6 AN fitting with 1/8" NPT threads that would work to adapt a larger tube.
thanks for the info ;). i think i'll get a 1/8 npt to 6AN. and then get a hose end thats a 45 degree 6AN to 6AN.
