Transmission mount - ugly and unknown converter
cudajames
San Jose, CA
I am in the process of upgrading my engine/transmission
So of course, step 1 is to remove the old
Check out this transmission mount - I am guessing that is original and I will not be reusing
Can not see the entire part # - but 2533#6
It is not listed in the reference area (Barracudas and their cousin Valiants usual are) would this work - Energy Suspension Transmission Mount. If not there is a stock replacement for $15
Also here is some info on the converter - it is not the original and the area code is Washington - which is where my car originally ran around. Can anyone tell from the part # 2002527 if this is a stock replacement (which I think it is). I will be using a Dynamic Converter with the new engine
Pretty interesting
That's the correct trans mount. Depending on your build, you could run the stock one. 65'
I have been able to find the trans mount. Now I am looking for the bumper above the transmission - does anyone know if that has been remanufactured? Or where to get one. I haven't checked the existing one yet - but I have to imagine it is the original and worth replacing with the tranny out
