Trimming piston skirts
HotrodColt
Grand Rapids Michigan
I have a set of seven 7025 pistons, was told that the TRW 2295 were the same so I bought one to complete the set and I noticed that the piston skirt on the 2295 is about 1/8” shorter than the 7025. Would it be ok to chuck up the other seven in a lathe and trim them down to match the 2295?
See post 3. As long as the weights are the same skirt length is not too critical.
:rofl:
That thread will NEVER die...
True that. The bad thing about bringing it up (like in post #2 above) is that the OP has no idea if the information is correct or sarcasm.
i figured if he knew enough to mention spinning them up in a lathe it was a safe assumption that he'd know i was goofin' about a ban saw. ;D
This is what I have on file.......compression height is different. Measure them
Part# CH Wt Pin Wt CCs Deck Ht
L2295 2.029 817 250 13.1cc .140 dome .051
7025P 2.050 815 250 13.1cc .140 dome .051
I have a 7025 030 over slight scuff on skirt. You can have it if you need it.
Measure the easy way, put both pistons on one pin... You'll only get one pin boss per piston but they will be perfectly matched at the pin bore...
