Truck Dipstick Tube Help Needed
I traded a front sump even up for a late 60s a body pan last year and the guy wanted the front sump pan so bad that he offered to pay shipping both ways and put a set of oil pan gaskets in the tote with the a body pan..... He had a 68/69 truck (for which a front sump was designed for) and a "car" engine he was trying to put in.
What you putting it in
Mine came with a rear sump...I know it was a swap
Not oe to the truck
Some guy needed a rear sump and traded
His was all clean and painted
Mine looked like shizt
Whichever truck I find when I finally have some dough. Now I have pans for both the 71 and back and 72-93. I'm real partial to the 73-73 trucks but good luck with that. lol
Oh and her's the finished front sump project.
Yes i like the 72.....
Was never i swept line fan
More of a different then anything else fan
And the fo loovers on the hood are cool
The slant 6 trucks had at last two different styles of rear sump oil pans. One, where the dipstick tube inserts into the side of the oil pan and another where the dipstick inserts into the block, like conventional car engines do. I am needing the length of the dipstick tube for the truck engine that takes the dipstick tube that inserts into the block. A picture would help, too. @halfafish ? Maybe you have one? This is not a parts wanted thread. I can easily make a tube. I just need the measurements.
I would go and find a slant 6 van in a junkyard and use the whole dipstick setup. The tube will be higher up, so much easier to reach when checking the oil.
I know the 71 and up had "REAR" sumps for trucks and vans, but will not fit in cars. If you can make them fit, you can increase your oil by one Qt.. Just make sure you grab the pick-up also.
Yeah, no doubt if you gotta have one you gotta have one. They ain't growin on trees. As many millions of slant sixes that were made, I cannot believe no one makes an aftermarket pan for any of them.
I have the dipstick and tube for the rear sump pan. The pan in this thread is a front sump pan. It takes a dipstick tube that installs in the block similar to a car. I can make that.
I still have the parts truck
65 225 ...if you need something off it
Mine has the stupid cast iron bell that has the trans mounts on it
You need to remove the clutch and flywheel to get to the top bell housing bolts from the inside...pia when the motor is stuck..thing has to weigh 40 lb
Sounds like a flathead carryover part, last FH in 64 0r 65 IIRC.
Does bell fit both? Anyone know?
That has mounts on it too
Ill post a pick of my 67 one
this is the bell
i guess it fits v-8 too
slant upper bolts are on the inside
funny looking at the pic it uses a hydro clutch wonder what the hole is for
and the screw ?
and the screw ?
Those early hydraulic clutches could be very problematic! They used them on some larger trucks, too. Peddle feel poor.
and the screw ?
The screw retains the clutch fork ball and the hole is where the fork goes through. The slave cylinder and clutch fork are on the passenger's side.
Yes thinking the screw is the adjustment for the ball pivot
For some reason I thought the hydraulic went inside the bell
Took it apart 4years ago
and the screw ?
Screw is throwout fork ballstud. Window to remove fork before removing trans & to mount fork boot.
Then the throwout bearing can be slid on nose of trans before installation, no floppy fork to line up.
so this is the engine side wounder how many engines this would fit
Above starter hole looks like a hydraulic pump or marine W/P bolts there & bell is cover for pump.
Might fit forklift app, industrial engines, maybe farm apps. Probably not marine, as they never used those mounts & it's too heavy.
Military Museum had an Aircraft Tug with a Slant Six.
The inner bell asymmetrical shape fits rear of Flatheads' block.
A better picture of the Casting Numbers, date codes and any stamped numbers and letters you find, might help ID it, too.
Looks like the one from my 61 w200. It has the low mounted 3 bolt starter and several different engine bolt patterns.
Mine will work with the slant six and the flathead six, and there are 2 v8 patterns… I assume the A engine and hemi but not sure. Definitely not big block.
Being a 61 I think all the engines except the slant would be the longer flange with eight bolt crank, the slant had a weird flywheel with a spacer cast into it
LOL I'm pretty sure I'd be drillin a couple of access holes through the back of the bell, or is the flywheel still in the way?
its off my 67 d100...i guess they just used a one size fits all ,ill see what come off the 65 parts truck when i pull it
