trunk lid skin - how attached?
Mopar Body and Trim
  1. jcmeyer5
    jcmeyer5 FABO Gold Member FABO Gold Member
    210
    199
    Jan 7, 2019
    Indiana
    Local Time:
    12:27 AM
    I am working on a 69 Dart. I pulled the trunk lid to strip and epoxy this weekend. As I was stripping out the old seam sealer around the inside lip (had a bit of surface rust in spots, needed to media blast), I noticed that it appears that the skin was tacked on. I expected a spot weld, but it is held on with a teenie tinnie little tack weld at several places around the skin. Is that right? They dont look terribly strong, but if they are original, I wont mess with them.
  2. JDMopar
    JDMopar Well-Known Member
    2,794
    1583
    Jan 19, 2012
    Candler, NC/Myrtle Beach, SC
    Local Time:
    12:27 AM
    They have held it together for 50 years...so I'd leave them alone, lol. Just dig out all of the old seam sealer all the way around the lip, blast it clean, epoxy prime it, and them re-apply new seam sealer. Let the seam sealer set up, and then paint it body color.
    • Agree Agree x 1
    • Dana67Dart
      Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
      4,123
      2494
      Jul 16, 2017
      Northern Colorado
      Local Time:
      10:27 PM
      I thought the trunk skin was attaches to its structure by a rolled edge like a door skin and some dollops of adhesive between the two in the center area?
      • Agree Agree x 1
      • jcmeyer5
        210
        199
        Jan 7, 2019
        Indiana
        Local Time:
        12:27 AM
        It is definitely rolled over the inner structure, but it also has these small welds all around the perimeter. I'll get some pictures tonight to share.
        All clean, awaiting epoxy, which will happen tonight.
        • Like Like x 1
        • Dana67Dart
          4,123
          2494
          Jul 16, 2017
          Northern Colorado
          Local Time:
          10:27 PM
          Now I'll have to look at mine.
          Are they visable while painted?
        • Fred Scigliano
          Fred Scigliano Lots of money
          13,474
          17053
          Nov 26, 2017
          NORTH DAKOTA
          Local Time:
          11:27 PM
          Yep factory did it like that, seen many in the last 45 years of being a body man and replacing door skins.
          Just a thought before you epoxy prime if your trunk lid is like my 73 Scamp you might want to coat the inside between the 2 skins with something because I know the factory didn't put enough corrosion protection in there. A bore scope will show you all the rust between the panels.
          If you tape all the holes up and poor something like POR-15 or what ever you chose to use and coat the inside it will last longer by sealing up the rust.
          Just my 2 cents.
          • Like Like x 2
          • Agree Agree x 1
          • jcmeyer5
            210
            199
            Jan 7, 2019
            Indiana
            Local Time:
            12:27 AM
            I’m kinda running out of weather here in Northern Indiana. I can do the POR later, but today I need to do the epoxy. I did see the rust in there, particularly back at the hinge pockets
          • Fred Scigliano
            13,474
            17053
            Nov 26, 2017
            NORTH DAKOTA
            Local Time:
            11:27 PM
            Yes Epoxy ASAP good call.
          • jcmeyer5
            210
            199
            Jan 7, 2019
            Indiana
            Local Time:
            12:27 AM
            Here are two of the tacks. Just for information
          • jcmeyer5
            210
            199
            Jan 7, 2019
            Indiana
            Local Time:
            12:27 AM
            Epoxy is done on the bottom of the deck lid. Top gets done tomorrow.
            • Like Like x 2
            • Fred Scigliano
              13,474
              17053
              Nov 26, 2017
              NORTH DAKOTA
              Local Time:
              11:27 PM
              Yep factory mine is the same. Kinda shitty tack weld but that's how it was done back then.
              • Thanks! Thanks! x 1
