moparmat2000
I have a trunk light wiring harness. Not OEM. Custom made w new wires and brass connector pins, and reusing original plastic connectors made to original length and color code. Its plug n play. Needs a bulb and switch. I probably have a phillips self tapper screw i can put in with it. Bulb socket is not OEM, however it will attach the same way as OEM, and uses the same bulb. Asking $40 plus flat rate shipping. Located in west Texas. I accept paypal.
