Trying for hours now... 65 Valiant left exhaust manifold problem
Small Block Mopar Engine
  1. Schyrjajew
    Schyrjajew Well-Known Member
    83
    35
    May 5, 2017
    Switzerland
    Local Time:
    4:56 PM
    I got a problem. For hours I have been trying to remove the left manifold from my 65 273. As explained in the book and video, I have removed everything before (brake booster, linkage to transmission, exhaust pipes and braces. But I just can't pull the manifold out. No matter how I turn it or move it around, the end always gets stuck between the engine and the steering linkage. Does anyone have a tip?
  2. 66fs
    66fs FABO Gold Member FABO Gold Member
    4,682
    1406
    Sep 9, 2009
    Greenwood, South Carolina
    Local Time:
    10:56 AM
    You can loosen the drivers side motor mount, the one nut underneath the car, and gently jack the motor up just enough to slip the manifold out. Use a block of wood between the oil pan and a jack.
    • Like Like x 3
    • Agree Agree x 3
    • Veryfastdart
      Veryfastdart FABO Gold Member FABO Gold Member
      564
      108
      Feb 28, 2010
      Hampton NH
      Local Time:
      10:56 AM
      66fs has the cure, that's how I've done it in the past.
    • pishta
      pishta I know I'm right....
      17,316
      6926
      Oct 13, 2004
      Tustin, CA
      Local Time:
      7:56 AM
      I thought the starter needed to be removed then it would snake up from the bottom? I could be way off, hadnt had manifolds since '98. loosen mount nut under frame and jack for clearance. did yours have a brace? What plant was it built at, seems LA plant cars didnt get the brace?
      • Agree Agree x 2
      • Schyrjajew
        83
        35
        May 5, 2017
        Switzerland
        Local Time:
        4:56 PM
        Thanks, gonna try it like this on saturday
      • furrystump
        furrystump Well-Known Member
        1,024
        645
        Nov 13, 2004
        Local Time:
        3:56 PM
        I jack it up and put a big deep socket between the k frame and the motor mount. Holds it up while you have your hands in there.
        • Like Like x 1
        • harvenator
          harvenator Well-Known Member
          349
          8
          Sep 22, 2008
          Braden, TN 40 miles East
          Local Time:
          9:56 AM
          Disconnect the steering column from the steering.box. you may also have to remove the valve covers to give you a little more room. Just went through this last week on a 65 Barracuda.
        • Schyrjajew
          83
          35
          May 5, 2017
          Switzerland
          Local Time:
          4:56 PM
          Jackin up worked. Thanks :) IMG_20191205_143742.jpg
          • Like Like x 2
