TTI header and 3" x-pipe exhaust install 69 Cuda
Mopar Exhaust Systems
  1. OnEbAd340
    OnEbAd340 Well-Known Member
    77
    28
    Mar 19, 2006
    RI
    Local Time:
    11:35 AM
    TTI was great to deal with and couldn't be happier with my purchase.
    My engine is a run of the mill 340 with x heads. Milodon Road Race oil pan, Chrysler Denso starter, man steering, 11/32 tie rods,biscuit mounts, poly trans mount.
    20200624_085356.jpg 20200624_085348.jpg 20200624_085412.jpg 20200624_085434.jpg 20200624_085329.jpg 20200624_085321.jpg
    Chassis is bone stock, minus the bolt in suspenion parts. The 3" pipes have a lot more clearance than I expected. Had to cut about 5" off the reducers, and 3" off the tail pipes for the tips.
    Also looks like I can get away with a 3.5" alum driveshaft if i wanted to. Hope this helps, as I was searching FABO a lot before buying and a lot of the threads AutoX and others have done are now getting old, nice to see nothing has changed fitment wise.
    • Like Like x 4
    • Thanks! Thanks! x 1
    • toolmanmike
      toolmanmike FABO MODERATOR Staff Member FABO Gold Member
      50,379
      35366
      Jan 18, 2006
      Iowa
      Local Time:
      11:35 AM
      Looks great. That's a favorite color too.
    • OnEbAd340
      77
      28
      Mar 19, 2006
      RI
      Local Time:
      11:35 AM
      20200708_144448.jpg 20200708_144524.jpg 20200707_144930.jpg 20200708_134716.jpg
      • Like Like x 3
      • OnEbAd340
        77
        28
        Mar 19, 2006
        RI
        Local Time:
        11:35 AM
        Thank you! Car was repainted R6 in the early 90s, Im glad I put it back to the orig color
        • Agree Agree x 2
        • doug 371
          doug 371 Well-Known Member
          1,969
          209
          May 29, 2004
          Regina, SK CANADA
          Local Time:
          5:35 PM
          Looks great!
        • OnEbAd340
          77
          28
          Mar 19, 2006
          RI
          Local Time:
          11:35 AM
          Thank you!
        • Steven190
          Steven190 FABO Gold Member FABO Gold Member
          1,147
          559
          Jan 13, 2012
          Omaha
          Local Time:
          11:35 AM
          Nice
        • 72Dart6pack
          72Dart6pack Harder Better Faster Stronger.
          3,624
          3284
          Feb 1, 2016
          Roseville Michigan
          Local Time:
          12:35 PM
          Do you have any photos of the muffler hangers bolted to the underside location? I'm currently working on my TTI system and could use a nice shot of that. Thanks.
        • doug 371
          1,969
          209
          May 29, 2004
          Regina, SK CANADA
          Local Time:
          5:35 PM
          you take the seat belt bolts out that you see in the picture and use tti supplied bolt...then the hanger hangs from that...
          • doug 371
            1,969
            209
            May 29, 2004
            Regina, SK CANADA
            Local Time:
            5:35 PM
            hard to tell from the pic...maybe your bolts are already out...
          • 72Dart6pack
            3,624
            3284
            Feb 1, 2016
            Roseville Michigan
            Local Time:
            12:35 PM
            Not all applications will that work. As in my Photo.
          • 72Dart6pack
            3,624
            3284
            Feb 1, 2016
            Roseville Michigan
            Local Time:
            12:35 PM
            Thanks. Anyways.
          • OnEbAd340
            77
            28
            Mar 19, 2006
            RI
            Local Time:
            11:35 AM
            The reinforcement plate is where the seat belt bolt goes through. You either have the bolt in there or its not. Hard to tell from pictures. but that mount bolts there, roughly 5 inches down from where it was in that picture
          • 72Dart6pack
            3,624
            3284
            Feb 1, 2016
            Roseville Michigan
            Local Time:
            12:35 PM
            The combination that worked for me was 4.5 inches above the seat belt mounting bolt to keep the brackets straight. Just finished mine tonight. If you look close in the 2nd photo. The seat belt hole wouldn't work.
          • wils841
            wils841 Old School
            108
            16
            May 4, 2011
            Colorado (prev Texas)
            Local Time:
            11:35 AM
            nice build onebad340!!! Is your TTI exhaust direct from them, or a third party (magnum force?)... also, are the tailpipes a full 3 inch diameter also, or did they need to be necked down for axle housing clearances? Thanks! mark...
          • OnEbAd340
            77
            28
            Mar 19, 2006
            RI
            Local Time:
            11:35 AM
            Thank you!. I dealt with Mike at TTI direct, he sends you an invoice on Paypal and you pay through Paypal direct. Couldn't be easier. I didn't want to deal with the middle man. The exhaust is full 3" the tips are 3" inlets as well. So far no clearance issues.
          • jbc426
            jbc426 Well-Known Member
            1,821
            644
            May 30, 2007
            West Coast
            Local Time:
            9:35 AM
            Often times a man's life out here depends upon a mere scrap of information.
            That being said, I had to reroute my spark plug wires on my 5.9 as indicated in the factory service bulletin to get rid of a mis-fire that showed up on my scanner data.
            Here;s the info...
            5.2/5.9 Misfire TSB 18-48-98
