1. cuda620
    cuda620 Well-Known Member
    1,601
    144
    Oct 26, 2014
    indiana
    Local Time:
    6:17 AM
    Anyone able to report on tti header fitment on an A body with manual steering and brakes and a B engine? Thanks.
  2. sabre67
    sabre67 FABO Gold Member FABO Gold Member
    956
    224
    Jan 9, 2015
    British Columbia,Canada
    Local Time:
    4:17 AM
    :popcorn:
  3. Dragonsteel
    Dragonsteel Well-Known Member
    203
    230
    May 12, 2015
    Missouri
    Local Time:
    6:17 AM
    TTI small tube shorties in my 71'Dart with manual steering. They fit great IMO.
    • Like Like x 2
    • Thanks! Thanks! x 1
    • 33IMP
      33IMP Well-Known Member
      339
      337
      Jul 3, 2020
      Taxifornia, soon 2b arizona
      Local Time:
      4:17 AM
      I cant help with your question, but i can point out we need more info. Are you talking about an early a, up thru 66, with the small engine compartment, or the 67 up cars with the bigger engine compartment, where a big block at least fits?
    • mygasser
      mygasser FABO Gold Member FABO Gold Member
      670
      366
      Aug 17, 2010
      faversham, kent. united kingdom
      Local Time:
      6:17 AM
      they fit the earlier cars, it's tight but they fit. i even did head gaskets on the 440 in my 65 dart in situ.
      neil.
    • cuda620
      1,601
      144
      Oct 26, 2014
      indiana
      Local Time:
      6:17 AM
      67
    • SuperStock426
      SuperStock426 FABO Gold Member FABO Gold Member
      269
      159
      May 20, 2020
      Fort Oglethorpe Georgia
      Local Time:
      7:17 AM
      Not on a B..But I have the 2 inch This on my RB in my 71 Demon.
    • cuda620
      1,601
      144
      Oct 26, 2014
      indiana
      Local Time:
      6:17 AM
      Did u have to dent the #7 pipe?
    • SuperStock426
      269
      159
      May 20, 2020
      Local Time:
      7:17 AM
      I had to ding #1 where it comes back and drops down to where my steering coupler wouldn't hit it.
      The ding you see on #7 was a factory ding from TTI.
    • cuda620
      1,601
      144
      Oct 26, 2014
      indiana
      Local Time:
      6:17 AM
      #7 around plug?
    • SuperStock426
      269
      159
      May 20, 2020
      Local Time:
      7:17 AM
      Yes sir.
    • cuda620
      1,601
      144
      Oct 26, 2014
      indiana
      Local Time:
      6:17 AM
      Sorry. For Dragonsteel.
    • SuperStock426
      269
      159
      May 20, 2020
      Local Time:
      7:17 AM
    • cuda620
      1,601
      144
      Oct 26, 2014
      indiana
      Local Time:
      6:17 AM
      Gotcha! 1.75 may fit better...
    • cuda620
      1,601
      144
      Oct 26, 2014
      indiana
      Local Time:
      6:17 AM
      Another member posted pictures to see
    • SuperStock426
      269
      159
      May 20, 2020
      Local Time:
      7:17 AM
      Most definitely 1.75 will fit better...Mine are 2 inch and tight.
    • SuperStock426
      269
      159
      May 20, 2020
      Local Time:
      7:17 AM
      I'd of run 1.75 but I'm running a pretty healthy 440 with Indy Heads so I went with the 2 inch.
    • AndyF
      AndyF Well-Known Member
      1,793
      1911
      Feb 23, 2009
      Oregon
      Local Time:
      4:17 AM
      They fit okay. I think they fit better on an RB block than on a B block. Looks like they were designed for the RB and so they just kind of fit on a B. They fit with a straight plug head but they'll fit even better with an angle plug head. I'll probably swap in a set of TF240 heads just to improve the access to the spark plugs.
      • Like Like x 2
      • AndyF
        1,793
        1911
        Feb 23, 2009
        Oregon
        Local Time:
        4:17 AM
        The headers are basically impossible to install or remove with the K frame in the car so be prepared to pull the K frame to change the starter. I bolted the engine all together and installed it from below. I tried installing the headers with the K frame in place and it just wasn't going to happen.
        • Like Like x 1
        • SuperStock426
          269
          159
          May 20, 2020
          Local Time:
          7:17 AM
          What type of block and headers are you using?..I can change my starter by removing just the torsion bar. I'm using a stock starter for a 96 Dodge truck which is quite small. To remove the drivers side header I have to pull the torsion bar, disconnect the tie rod end and remove the steering box. To remove or install the passenger side header I have to jack the engine up on that side. I'm using a RB block with Indy Heads and 2 inch TTIs in a 71 Demon. I'm also using the stock biscuit style K-member that came with the car. I know some fellas like using the newer 73 and up K-member that has the spool type mounts, but doesn't the spool type mounts cause the engine to sit a little lower than the biscuit style mounts?
          • Like Like x 2
          • cuda620
            1,601
            144
            Oct 26, 2014
            indiana
            Local Time:
            6:17 AM
            Was thinkin bout Andy’s build using C body hp manifolds. Kinda gotta do a B engine as I’m building a 451. I wondered if tti headers sat down on the torsion bars compared to the RB engine....
          • ls23h
            ls23h FABO Gold Member FABO Gold Member
            420
            1536
            Oct 5, 2009
            New York State
            Local Time:
            7:17 AM
            Andy F, What is the background of the k frame stand in this photo? Is this something you built, or was it purchased? 6E0000C0-36D4-436F-A62F-7DCAFB871161.jpeg
          • SuperStock426
            269
            159
            May 20, 2020
            Local Time:
            7:17 AM
            The headers are close to the torsion bars on mine.
          • AndyF
            1,793
            1911
            Feb 23, 2009
            Oregon
            Local Time:
            4:17 AM
            It is a transmission jack plus some brackets that I fabricated.
          • AndyF
            1,793
            1911
            Feb 23, 2009
            Oregon
            Local Time:
            4:17 AM
            Yes they do sit down on the torsion bars and they are tighter to the block than on an RB. The headers fit but you have very limited access to things. As I said above, the K frame has to be removed to change the starter. If you're okay with that then go for it. When I talked to TTi about the fit they said that the headers could be installed or removed if the car is on a two post lift. I don't have a two post lift in my shop so that option doesn't work for me.
