moparspares
What are my options. As far as I can see from research it is either Weiand or Indy and I do not like indy due to cost unless I can get used. I will be using Trick flow 270 (Max Wedge Ports). Can I take the Weiand out to max wedge size or do they become pretty thin. I have also heard there was 2 different part numbers for Weiand with one having more meat around the ports.
Any light you can shed on this would be helpfull or if you have used of these I may be interested.
. still cheaper than a 'proper' fe tunnel ram...... if you can find one. at least bbm intakes are available, lol.
