project360
what would be needed for a 2x4 tunnel ram motor ??
cam ?
compression ?
cam ?
compression ?
A motor, a tunnel ram and two carburetors.
eddy street ram, 390 holleys,custom schneider cam 284/234@50 470 lift 112 lsa.10:1 comp.despite how everyone told me it would run like crap and that"it was strictly a high rpm set-up"it has great street manners and is very responsive down low.strokerscamp basically hit the nail on the head.
exactly.....and im running a 2200 stall to answer your question.Lemmie tell you sumthin......if you got the right bottom end....with that Eddy street tunnel ram, you can run a STOCK converter and make it run nice on the street......so that just means the benefits of any kinda stall will be ten fold. As long as you stick with that street tunnel ram and watch the carb sizes, the rest will kinda fall into place. Just don't cheap out on one of them weiand's or somethin similar. They are not bad tunnel rams....but they are not designed for the street. The Eddy is.
i ended up getting the eddy street ram from a member in the classifieds, cant wait to see it !!
--now just need to find some 450s
