1. pishta
    pishta I know I'm right....
    21,733
    11134
    Oct 13, 2004
    Tustin, CA
    Local Time:
    7:43 AM
    plus your heating that 3" tube on that long haul and then the heat has no where to go except back into the charge until it can lower itself to ambient tempa again. Hows the lag on that remote boost? I suppose a truck is not really an issue but in a car that may be something to think about.
  2. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    81,266
    60779
    Jun 7, 2010
    Georgia
    Local Time:
    10:43 AM
    That's lookin purdy dang good so far!
  3. TT5.9mag
    TT5.9mag Two atmospheres are better than one
    2,112
    2109
    May 5, 2016
    So cal
    Local Time:
    7:43 AM
    I don’t really have a comparison for the answer to your lag question. Everyone asks me that same thing but I e never had this engine with this turbo set up any other way. I can tell you this, when I step on it and it downshifts from 5th to 3rd it’s in boost faster than I can look at the gauge.
    • Thanks! Thanks! x 1
    • RustyRatRod
      81,266
      60779
      Jun 7, 2010
      Georgia
      Local Time:
      10:43 AM
      If I can figure out how to make it look good, I might do it. I just got the block back from havin .055" whacked off the deck. I said whacked off. So now, it's a zero deck height engine. So I'll need to use the thickest head gasket I have which will be somewhere around .045" compressed thickness. That will give it about a true 9:1. It's still gonna need a pretty big cam though. Something to ponder. It's gonna have to be where I can make it a neat freak, or it's not gonna happen.
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
      22,043
      9219
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      9:43 AM
      no I can't, on account of I have no experience.
      But IMO, I don't think your being fair;
      the question I would put forth is this;
      Suppose your system was under the hood in the usual place, and NOT running an intercooler. What might be the charge temp?
      Now run the plumbing for the intercooler but substitute a 15foot X3inch aluminum tube (or however long your current piping is), in it's place; what might be the new charge temp?
      And finally, install the intercooler and generate the final temp.
      In your story, you left out the first part, for obvious reasons, I can see that. But what if.
      As to turbocharging, I can only parrot what smarter men than me have to say.
      As for myself; If I owned an Early-A and got the urge to turbo it, I would try to run a water/meth injection system before I would run an intercooler hung off the front.
      But before that, I would for sure at least try a remote, and possibly a 2-stage; that's my dream BTW,lol. Not for mega-power, cuz there is no way to harness that on the street anyway, in a stock-body Early-A, lol. But for two things; 1) the cool factor, and 2) tire shredding torque just off idle.
      In my dream, I would run a small turbo under the hood just to get the ball rolling, and feed the exhaust from it, along with an exhaust bypass, out to a bigger turbo out back.
      My intercooler(s) would be disguised as LakerPipe(s) sending the charge-air back to the front. Hey, it's my dream,lol.
    • Killer6
      Killer6 Well-Known Member
      3,010
      1111
      Mar 9, 2015
      PA
      Local Time:
      9:43 AM
      Relying on water-meth injection sucks, I know, cause if it ever runs low or F's up(& at some point it will) it can ruin a lot of hard work and expensive/irreplaceable parts. Luckily when the piston ring lands collapsed on the turbo'd 340 My Bud was running in the AAR at the time, it didn't destroy the T/A head or block. The injection We were running stopped working around the 1/8mi mark, & that's all she wrote....
    • RustyRatRod
      81,266
      60779
      Jun 7, 2010
      Georgia
      Local Time:
      10:43 AM
      Yeah, IF I ever do a turbo build, it'll have an intercooler. "Somewhere"
    • Bodyperson
      Bodyperson Pedal to the metal FABO Gold Member
      7,135
      10248
      Nov 26, 2015
      NW MONTANA
      Local Time:
      8:43 AM
      You have some bodyshop friends? I've scrapped a lot of usable intercoolers.
    • RustyRatRod
      81,266
      60779
      Jun 7, 2010
      Georgia
      Local Time:
      10:43 AM
      I do....but I wasn't worried about where to get one, but where to put it. lol
    • Bodyperson
      7,135
      10248
      Nov 26, 2015
      NW MONTANA
      Local Time:
      8:43 AM
      Ya I realized that. Just thought I'd throw that out there.
    • dirty white boy
      dirty white boy 50 yr old Juvenal delinquent
      1,737
      1139
      Dec 15, 2012
      stoneville n.c.
      Local Time:
      9:43 AM
      dosent have to be an air to air charge cooler!! all the turbo'ed diesels in big trucks were water buffalo's for decades!!! water to air charge cooled! it would give ya more options but most likely more tubing.... id run a pyrometer on it before turbo,...aluminum melts at ruffly 1200 degrees!!
      • Like Like x 1
      • Agree Agree x 1
      • Cruisingram
        Cruisingram Well-Known Member
        234
        100
        Dec 1, 2020
        Pahoa, Hawaii
        Local Time:
        5:43 AM
        Do you plan on running a mechanical fuel pump? from what I understand, you can't run much over 6 or 7psi- then you probably are in range. I don't know much as you guys about the sixes, but have done plenty v8s.
      • RustyRatRod
        81,266
        60779
        Jun 7, 2010
        Georgia
        Local Time:
        10:43 AM
        I don't know yet. I am still in the pondering stage. It will probably just end up being another N/A build.
      • TT5.9mag
        2,112
        2109
        May 5, 2016
        So cal
        Local Time:
        7:43 AM
        Sounds like i ruffled your feathers a little. I certainly didn’t mean to. My question was meant to ask you what a 2 stage system is. It sounds like you mean a compound system. If so those are used mainly to generate very high pressure ratios and lots and lots of “map width”. The diesel puller guys love em. And they are making sometimes 200 or more psi with compound triples, (2 small twins feeding a monster). There are not a lot of successful gas engines running compound setups. The boost gets out of hand very quickly. So I’ll ask again is that what you meant by 2 stage? And to the first part of your reply, I gave you a direct first hand experience of running a remote mount turbo on my personal vehicle with ~14 feet of tube and no intercooler and then with an intercooler and gave you the temps from my data logs. It’s about as fair (and accurate) as anyone can be I don’t get it.
      • TT5.9mag
        2,112
        2109
        May 5, 2016
        So cal
        Local Time:
        7:43 AM
        Smart man. It’s free horsepower. And it doesn’t get any easier than an air to air.
      • AJ/FormS
        22,043
        9219
        Jan 19, 2014
        Local Time:
        9:43 AM
        not at all. I am ignorant of practical turbo. Sorry if I came across as ruffled,lol. That just was not my intention. Like Rusty often says; drive thru.....
      • clementine
        clementine Flight risk FABO Gold Member
        1,984
        1426
        Jan 3, 2016
        Emerald city
        Local Time:
        7:43 AM
        rear mounted turbo with a 100 shot of nitrous. Use the nitrous above 3K rpm of course but it would get it up and running so you would have no lag.
      • BillGrissom
        BillGrissom Well-Known Member
        7,615
        501
        May 10, 2009
        Sacramento
        Local Time:
        7:43 AM
        To throw another angle, view youtubes of the new after-market motorized superchargers. Some of the more expensive ones ($500+) actually add appreciable power, while cheapies sometimes add more restriction. Much easier install, allowing more flexible plumbing than a turbocharger. No question they "could work" if you've viewed past youtubes of people who rigged a gas leaf-blower into their intake. I have no personal experience.
      • Don Selleck
        Don Selleck Active Member
        38
        38
        Aug 5, 2019
        michigan
        Local Time:
        10:43 AM
        I'm contemplating a remote turbo build also, with a slant six, some very good info here on some of the things i was wondering about. I was only going to run around 8 psi, nothing too wild with 600 mechanical secondary blow thru, 9:1, forged piston and lighter rods just for insurance. powering a 2500lb dodge truck. sounds like an intercooler is the way to go. was looking at the STS system from holley, comes with is own oiler kit. kinda pricey, but a remote is my only option because of limited space under the hood, and don't wanna have that all cluttered up either.
      • TT5.9mag
        2,112
        2109
        May 5, 2016
        So cal
        Local Time:
        7:43 AM
        Be very cautious about the oil pump STS sells with their kit. The brushes die in them about every 2000 miles. I went through 2 of em before I got an exapump from turbowerks. Very expensive but you’ll never worry about it ever again. Mine has over 400,000 miles on it.
        Exa-Pump is #1 Worldwide
        • TT5.9mag
          2,112
          2109
          May 5, 2016
          So cal
          Local Time:
          7:43 AM
          With a slant 6 having a narrow powerband, 1500-5500 or so, if you’re not at full boost pressure or damn close to it at 3000 rpm you have the wrong size turbo. And usually a small hit of nitrous is used initially to spool a turbo sized larger than optimal. So if you’re racing it, I suggest using the nitrous at the hit and killing it before peak torque. Let the boost take over from there.
        • Don Selleck
          38
          38
          Aug 5, 2019
          michigan
          Local Time:
          10:43 AM
          I have a free td40 subaru turbo with less than a 1000 miles on it, in brand new condition and a few goodies including an intercooler to go with it, thinking I will be working with this instead of the sts system. spooled up on a 4 cylinder at around 3200, might be the answer, probably using the exa pump, and making an oiling system, thanks for the advice TT5.9mag.
        • KosmicKuda
          KosmicKuda FABO Gold Member FABO Gold Member
          2,260
          994
          Jan 15, 2011
          N Ohio
          Local Time:
          10:43 AM
          Assuming identical pressure, the resulting force from a 3.4 bore is 72% of a 4.0 bore.
          pi x radius squared
        • RustyRatRod
          81,266
          60779
          Jun 7, 2010
          Georgia
          Local Time:
          10:43 AM
          I've done a TON and I mean a TON of reading on turbos. From what I've gathered, for best street acceleration, it's actually best to choose a turbo that's just a tic smaller than you need. Similar to how some of the diesel boys do it. The smaller turbo spins up quicker. But too small and the power benefits fall off drastically.
          • Agree Agree x 2
          • TT5.9mag
            2,112
            2109
            May 5, 2016
            So cal
            Local Time:
            7:43 AM
            There is a very fine line actually. Too large and it won’t spool soon enough and it will lag. Too small and backpressure will will be too high and the thing won’t make any power. The correct way to do it is to read and understand a compressor map and size the turbo for a specific engine. At maximum airflow requirement the compressor should be in the 70-90% efficiency zone on the map. Which will keep the turbo out of surge and keep backpressure at reasonable levels.
