turn signal wiring
burks440
alabama
can some 1 post a picture of front turn signal bulb ground as to where it is screwed to the body as a ground i am talking about the ground wire that is connected to the bulb socket on a 71 dart in front of car
I am at work but could post one later. It's to the driver side of the radiator on the core support towards the top. It grounds to the same point on the body as the battery
I’m pointing to the grounds for the light forward harness.
