Twin 76’s, 92 octane,10lb wastegate springs
Hemirunner
Down South
And a leaking exhaust valve... ugh
Just 1 valve? Hopefully not a material problem that will affect the other 15.
Just one as far as I can tell. You can hear it at idle and it seems to go away with rpm. The engine is coming apart anyway to tighten the main bearing clearance and put in a different rear main seal. I’ll just do the seats and valves while it’s apart.
