Twin turbo duster update
414 DUSTER
pa
I just thought I would give an update on my project. It's been a long road tring to get this car straight out. Lot's of problems , but the biggest one was traction. Last weekend it showed a little bit of what it could do. It ran 8.77 @ 153 with a 60 ft of 1.28 . I think next year will be even better.
Ok sorry . I tried to post a video but it wouldn't let me. I might be able to post a older one. Here are some pictures.
Great times! Have you posted the engine and turbo specs somewhere? I'd love to know more about the combo. What transmission?
I haven't posted anything but I can give you some idea . It starts with a r3 59 deg block. Molar 4 inch crank and rods . Diamond custom Pistons and rings 9 to 1 compression. Indy 360-2 cnc heads. Victor 340 intake . Csu 750 carb. The turbo system I had a trend on you can look it up. Twin 66 mm borgwarner turbo's. I'm running a 727 transmission . No Chevy hood no Ford rear ALL MOPAR.
….. and no LS..... :)
Wow that engine build is very similar to mine. I'm running a procharger though. I didn't go with an aftermarket block and probably should have that way I could turn up the boost someday. I'm only running 10 lbs. Roughly how much boost did you make on the 8.77 pass?
I launched at 7 and ramped to 20 psi. I have more for the future . Lol
If you search for a trend small block turbo duster . I posted it.
Cool, I looked at your thread. You said all mopar so you running a Dana 60? What's the rear suspension set up? Just curious, my best 60 ft so far is 1.38.
Yes I'm running a strange Dana ultimate 60. I mini tubed and moved the leafs in word . I'm running Calvert split mono leafs with sliders . Also ordered the leafs with pin moved back 5/8 of a inch to center wheel in wheel well. The shcks wouldn't work so I mounted the shocks in front of rear straight up. My best 60 foot so far is 1.28 but hoping for better. It's hard staying all Mopar . I've had lots of problems trying to get it worked out. I had to put meniscer shocks on . I can get and post pics if you want.
