jonn6464
1970 Duster
Hi FABO,
I'm trying to see if anyone has pics, UNDER THE DASH, of the factory wiring route for a Duster or Demon.
Mine is a 1970, but I would appreciate pics of any year.
I am installing an aftermarket wiring kit, and the instructions say to follow the factory wiring routing. But, the wiring was pulled out of the car years ago so there's nothing to go by.
I am mostly wondering about the retaining tabs ABOVE the gauge cluster on the back of the dash.
Where does the main wiring branch go when it leaves the fuse box? Up and around the gauges, then looping back towards the passenger fender?
Here is the fuse box, you can see the main branch goes out the top...
Here are the tabs above the cluster...
And then the tabs down along the bottom behind the glove box insert...
Thanks for any pics you have.
