under dash wiring
NMmoparman
Member
belen NM
having problems with wiring first I had no power to brake light switch now suddenly there's power but no signals when they worked before now no signals but emergency flasher work but no taillights thinking of just replacing under dash harness with new one from classic industries do you think this will solve my problems?
What car, what year, what wiring kit, what worked before you mage changes, why did you make chsnges
71 duster everything had always worked then noticed no brake lights so I replaced the switch and still nothing then noticed no power to switch then all the sudden it had power again but now no signals or tail lights but emergency flashers are working again and they had stopped working also
Personally I would never bother with replacing a harness, unless the car is undergoing a big resto. I have a '71 Demon and although the harness is basic, it's woven throughout the car like a spiderweb. I would much prefer getting on my back under the dashboard for an hour cleaning contacts than taking two weeks to pull everything out and put it all back in.
Probably need to check the wiring all the way back. Here is were you can get a diagram.
[/URL]
I would also add that when looking for a wiring diagram, look at several of them because, although one would think diagrams on the internet for a '71 Duster would be the same, they're not. I had to poke through four different diagrams until I found one that matched my car, due to incorrect and missing info on the diagrams.
Go to mymopar.com and download a copy of the factory service manual for your car. They have nice wiring diagrams. It's free.
