Universal steering couplers
Suspension, Steering and Chassis
  1. Belvedere66
    Belvedere66 Well-Known Member
    123
    19
    Jan 17, 2015
    Amelia, Ohio
    Local Time:
    9:43 AM
    Hey all, I have a 72 Demon with stock power steering box and stock column. My factory style coupler hits my headers and some had ground it down to a point where it's unsafe. I have a new stock coupler but it won't clear headers. I'd rather not fight with getting them off to beat the pipe in so I was wanting to find an easy replacement that would be a bit more streamlined and clear the header pipe. I don't want to spend an arm and a leg on a flaming river coupler. I'd like to be around $100 or less total cost with the least amount of modification as possible.
  2. Johnny Mac
    Johnny Mac www.blueprintengines.com FABO Vendor
    3,209
    2095
    Jul 10, 2010
    OHIO
    Local Time:
    9:43 AM
  3. rklein383
    rklein383 Well-Known Member
    1,444
    341
    Dec 2, 2005
    Local Time:
    8:43 AM
    • Like Like x 1
    • Belvedere66
      123
      19
      Jan 17, 2015
      Amelia, Ohio
      Local Time:
      9:43 AM
      I've seen the term DD used before. What exactly is a double d shaft?
    • Johnny Mac
      3,209
      2095
      Jul 10, 2010
      OHIO
      Local Time:
      9:43 AM
      It's a round shaft that has flats put on both sides. So it can't rotate inside a coupler.
      • Thanks! Thanks! x 1
      • Belvedere66
        123
        19
        Jan 17, 2015
        Amelia, Ohio
        Local Time:
        9:43 AM
      • thesiren74
        thesiren74 Well-Known Member
        987
        536
        Feb 23, 2014
        kenosha,wi
        Local Time:
        8:43 AM
        I used a coupler from speedway motors and welded/ pinned it.
      • RustyRatRod
        RustyRatRod 30 Degrees Outta Whack FABO Gold Member
        57,337
        26777
        Jun 7, 2010
        Georgia
        Local Time:
        9:43 AM
        Into a female hole of the same shape. Usually retained with a set screw and sometimes even welded in place.
      • thesiren74
        987
        536
        Feb 23, 2014
        kenosha,wi
        Local Time:
        8:43 AM
      • Johnny Mac
        3,209
        2095
        Jul 10, 2010
        OHIO
        Local Time:
        9:43 AM
        I forget the year cut off, but some have a telescoping shaft, that extends down, so that extra extension piece isnt needed. 73+ maybe? My 74 didn't need it
      • thesiren74
        987
        536
        Feb 23, 2014
        kenosha,wi
        Local Time:
        8:43 AM
        I just used it after converting to manual last year, i had the old coupler on it still before i changed headers.
      • SGBARRACUDA
        SGBARRACUDA ROY FABO Gold Member
        15,438
        4723
        Dec 7, 2006
        PLANT CITY FL. and PERRY GA.
        Local Time:
        9:43 AM
        I had the same issue on my 69 Dart with a set of CPPA headers. I wound up using a u-joint type coupler from Flamming River.
        • GMachineDartGT
          GMachineDartGT Senior Member
          1,588
          242
          May 9, 2006
          Huntington, NY
          Local Time:
          9:43 AM
          Even though many have done it, the original coupler has plunge built in to make up for chassis flex. All cars of the era had something similar. When you convert to a solid coupling, you eliminate this feature and put all the load on your column bearing.
          • Agree Agree x 1
          • Kernel Sanders
            Kernel Sanders eating chicken wings and drinking beer
            797
            77
            Nov 7, 2008
            Ottawa, Ontario, Canada
            Local Time:
            9:43 AM
            Please make note that the MA-Mopar 36 spline is NOT the same spline as the Corvair/Vega, they are NOT interchangeable and will NOT fit.
            • Agree Agree x 1
            • thesiren74
              987
              536
              Feb 23, 2014
              kenosha,wi
              Local Time:
              8:43 AM
              Had this for 2 years and about 8 thousand miles tighter than the factory ever could be with ample header clearance.
            • Belvedere66
              123
              19
              Jan 17, 2015
              Amelia, Ohio
              Local Time:
              9:43 AM
              Right, I believe it's is 0.620 36 spline. I found one at speedway motors for $50. The 5/8 ones are 0.625 so that's probably where people run into issues.
            • MOPAR4Me
              MOPAR4Me FABO Gold Member FABO Gold Member
              832
              127
              Jun 29, 2012
              Orange County, CA
              Local Time:
              8:43 AM
              • Like Like x 1
              • Johnny Mac
                3,209
                2095
                Jul 10, 2010
                OHIO
                Local Time:
                9:43 AM
                • Belvedere66
                  123
                  19
                  Jan 17, 2015
                  Amelia, Ohio
                  Local Time:
                  9:43 AM
                  Yeah that is my main question at this point. Do I get the 5/8" 36 spline or the 0.620" 36 spline?
                • moparmandan
                  moparmandan FABO Gold Member FABO Gold Member
                  1,967
                  1786
                  Jun 28, 2017
                  Central FL
                  Local Time:
                  9:43 AM
                • rklein383
                  1,444
                  341
                  Dec 2, 2005
                  Local Time:
                  8:43 AM
                  Some Mopars such as my e-body had a two piece shaft. I lubed mine up to allow slight in and out movement. Hopefully, that is enough.
                  • Agree Agree x 1
                  • SGBARRACUDA
                    15,438
                    4723
                    Dec 7, 2006
                    Local Time:
                    9:43 AM
                    The steering shafts are two piece anyway. So if it need to collapse or extend ever so slightly it will. The two pieces were only held in place by injected plastic.
                    • Agree Agree x 1
                    • GMachineDartGT
                      1,588
                      242
                      May 9, 2006
                      Huntington, NY
                      Local Time:
                      9:43 AM
                      True, but not all shafts have the nylon pieces free.
                    • SGBARRACUDA
                      15,438
                      4723
                      Dec 7, 2006
                      Local Time:
                      9:43 AM
                      I learned by pure accident how little it takes to collapse the two shafts, not thinking more than once I tapped the steering wheel to get the coupler on a steering box only to wind up with a column that was to short. I had to then tap them apart. I swear I think the plastic or nylon was put there to prevent a rattle.
                      • Agree Agree x 1
                      • GMachineDartGT
                        1,588
                        242
                        May 9, 2006
                        Huntington, NY
                        Local Time:
                        9:43 AM
                        It deteriorates over time.
