Upgrade intake manifold?
Small Block Mopar Engine
  1. Dave Haertel
    Dave Haertel Well-Known Member
    203
    34
    Sep 12, 2017
    Charleston, SC
    Local Time:
    8:00 AM
    Ok, so I currently have a dual plane Weiand Action Plus 8007 that was on the car when I purchased it. Took it off to solve a problem with the new distributor not seating correctly, needed to check the cam and oil pump gears.
    Now that it's off, and I can probably spring for a new intake if I wanted to, any suggestions on whether it's worth it to spring for an Edelbrock performer air gap? Or another intake you'd suggest?
    Details:
    340/360 (long story, still researching but believe it's actually a 360, not a 340 like I was told).
    Mild cam, not sure which one as it was built when I bought it
    Heads unknown as well due to same as above
    New 650cfm Holley 4 barrel.
  2. gliderider06
    gliderider06 Well-Known Member
    1,143
    174
    Oct 21, 2011
    Delaware
    Local Time:
    8:00 AM
    Thats already a good intake. May need a little bit of port matching to maximize its true potential.
    • Agree Agree x 3
    • Like Like x 1
    • 72Dart6pack
      72Dart6pack Harder Better Faster Stronger.
      2,783
      1820
      Feb 1, 2016
      Roseville Michigan
      Local Time:
      8:00 AM
      Go this route.
    • Dave Haertel
      203
      34
      Sep 12, 2017
      Charleston, SC
      Local Time:
      8:00 AM
      Is that a true T/A 6 pack manifold or aftermarket? I always heard they're too finicky to get into sync (the carbs)? Or is that an old wives tale?
    • Dave Haertel
      203
      34
      Sep 12, 2017
      Charleston, SC
      Local Time:
      8:00 AM
      Will have to find out which heads I have, guess I'll have to look around to find some numbers on those too.
      • Agree Agree x 1
      • crackedback
        crackedback FABO Gold Member FABO Gold Member
        18,032
        2042
        Aug 7, 2005
        92201
        Local Time:
        5:00 AM
        A good 4 barrel intake and carb will mudhole a 6 pack. Looks like tarzan.... LOL
        Keep what you have, save a bunch of money and get the tune up right. :)
        • Agree Agree x 4
        • Like Like x 1
        • Dave Haertel
          203
          34
          Sep 12, 2017
          Charleston, SC
          Local Time:
          8:00 AM
          Thanks, I've been told it's a good intake. But the performer air gap seems to be the one that everyone talks about.
        • Valkman
          Valkman Well-Known Member
          784
          226
          Sep 13, 2012
          NC
          Local Time:
          8:00 AM
          Stick with the weiand you probably won't get any real gains using anything else with the engine as it is. Spend your money elsewhere
          • Agree Agree x 3
          • Like Like x 1
          • Dave Haertel
            203
            34
            Sep 12, 2017
            Charleston, SC
            Local Time:
            8:00 AM
            Thanks. At some point in the next year, I'll be doing a top end on it, but figured I could do this one quick thing while it's off if it would have been worth it. The consensus seems to be to keep it.
            • Like Like x 1
            • 72Dart6pack
              2,783
              1820
              Feb 1, 2016
              Roseville Michigan
              Local Time:
              8:00 AM
              It is a real T/A 6 Pack manifold. This is what it looks like all done.
              • Thanks! Thanks! x 1
              • Dave Haertel
                203
                34
                Sep 12, 2017
                Charleston, SC
                Local Time:
                8:00 AM
                Dead SEXY. Beautiful.
                • Agree Agree x 1
                • 72Dart6pack
                  2,783
                  1820
                  Feb 1, 2016
                  Roseville Michigan
                  Local Time:
                  8:00 AM
                  408 6 Pack. It took a lot of work to get it to this level.
                  • Like Like x 2
                  • rumblefish360
                    rumblefish360 so close yet so far away
                    33,434
                    5498
                    Jun 21, 2005
                    New York, on a Island
                    Local Time:
                    8:00 AM
                    Wives tail. The people that tell you that ether never had one or can’t tune a carb properly.
                    While you do not nearly have enough information about your engine , never mind about the rest of the car and what your doing with it.... Insuggest sticking with the intake you have now. A switch to the Edelbrock doesn’t mean you will instantly make more HP or Tq.
                    We have a class racer here that always states;
                    “In my application the Weiand et’s better than the.....”
                  • Dave Haertel
                    203
                    34
                    Sep 12, 2017
                    Charleston, SC
                    Local Time:
                    8:00 AM
                    Thanks, yea, unfortunately I bought the car with the motor intact and it was a flip sale so I have no real idea what's in the motor. That's one of the reasons I plan on saving for the parts to rebuild it in the next year or two.
                    As for plans for the car, at the moment it's my driver and I anticipate it staying that way. I'm not interested in taking her to the strip, just having a peppy fun to drive small block that will light them up when I want and give me the adrenaline boost when I stomp her. No real idea as far as numbers go but I know these can easily get into the 350 plus both HP and Torque so I'm assuming at least that. I'll be doing some research on what to buy to get there and maybe I can re-use some of the parts, maybe not.
                    • Like Like x 1
                    • 12many
                      12many Well-Known Member
                      565
                      693
                      Dec 14, 2016
                      South Carolina
                      Local Time:
                      8:00 AM
                      Why not maximize what you have already? Bet that intake is ootb untouched. Carb a/f ratio and jetting dialed in? Ignition timing and curve ideal? Save the cash, port that thing! And maximize what you have. You'll gain more than you'd think. If you need pictures of work that can be done to one of those I got 'em. There's alot of room for improvement.
                    • Dave Haertel
                      203
                      34
                      Sep 12, 2017
                      Charleston, SC
                      Local Time:
                      8:00 AM
                      Seen a couple of YouTube's on porting them wasn't sure about the actual results and how much to truly take off.
                    • 12many
                      565
                      693
                      Dec 14, 2016
                      South Carolina
                      Local Time:
                      8:00 AM
                      All I did on mine was round/smooth the runner sides and roof of each from the plenum junction, and port matched and smoothed the runner roofs about 1-1/2" in. Smoothing and rounding, not really enlarging (other than the gasket match) is easy, and safe I'd say, and when you study that intake you'll easily see where the work needs to be done. I leaned heavily on David Vizard articles and others about typical proven results from simple clean-up of intakes without getting into extensive porting.
                      • Like Like x 1
                      • Dave Haertel
                        203
                        34
                        Sep 12, 2017
                        Charleston, SC
                        Local Time:
                        8:00 AM
                        Thanks, appreciate the tips. I'll have a look. Probably not putting it back together until this weekend so there's time to get a plan together.
                      • pishta
                        pishta I know I'm right....
                        13,710
                        3434
                        Oct 13, 2004
                        Tustin, CA
                        Local Time:
                        5:00 AM
                        Just look at the balancer. A Symetrical balancer (no weird off kilter weight cast in) would tell you if its a 273/340 or a external balance 360. Or you can always look on the passenger side of the block under the exhaust manifold for a big 340 or 360 casting.
                      • 318willrun
                        318willrun Stomper 4x4... we kept energizer in business
                        7,158
                        4957
                        Sep 13, 2013
                        I'm here
                        Local Time:
                        7:00 AM
                        I just did this thread...
                        Weiand Action Plus vs Edelbrock RPM
                        Also, no researching needed to see what motor you have. Crawl under the drivers side and look... it will say 340 or 360 or, or 318 :D. Or, you can look under the drivers head on the front of the block. Sometimes very hard to read here as I've seen the numbers were faintly stamped.
                        • Like Like x 1
                        • rumblefish360
                          33,434
                          5498
                          Jun 21, 2005
                          Local Time:
                          8:00 AM
                          Driver side of the block is easiest. The numbers are embossed (cast in/raised)
                          Look at The sequence of numbers, at the end of the long sequence, the displacement is cast in. And then a dash in a few numbers and a dash and stuff like that.
                        • Dave Haertel
                          203
                          34
                          Sep 12, 2017
                          Charleston, SC
                          Local Time:
                          8:00 AM
                          So the research question is because I had a mechanic swap the steering column for me, I’m just too old, and outta shape to be laying upside down and I probably would have had to pull the drivers seat anyway. So while he had it I had him spec it and there are 2 stamping done says 340 one says 360. I’ll try and get pictures of them both to upload maybe someone can help sort it out
                        • 318willrun
                          7,158
                          4957
                          Sep 13, 2013
                          I'm here
                          Local Time:
                          7:00 AM
                          Drivers seat?? you are supposed to be looking at the driver's side of the engine block. Anyone that changes oil for you can let you know what it says.... OR..... look under the drivers head at the front of the engine block. Flashlight and a wire brush may bring the stamp to light :)
                        • nm9stheham
                          nm9stheham Well-Known Member
                          9,930
                          2311
                          Dec 20, 2013
                          Waynesboro, VA
                          Local Time:
                          8:00 AM
                          Here is what you are looking for; it is under the exhaust manifolds way down on the side of the block. Use a mechanic's mirror (on an extendable stick) and a flashlight if you can't get underneath. The last 3 digits are separated from the rest and will be 360 or 340.
                          How to ID a Small Block Engine Block:
                        • Dave Haertel
                          203
                          34
                          Sep 12, 2017
                          Charleston, SC
                          Local Time:
                          8:00 AM
                          No, what I was saying is I'm too big to lay on the floor and change the steering column out, I'd have to take out the seat to fit. The mechanic that did the steering column did the ID and said it was a 340, I never followed up, but when I looked at the front stamping it said 360, thus the 2 different identifications. I'm under the hood today to put the manifold back on so I'll get a definite ID before hand obviously. I'll upload the pictures of the stampings.
                          • Like Like x 1
