Any tips on removing the upper control arm cam bolts?.. seems like they are frozen into the bushings, so I cant drive them out of the body mounts because it is hard to get a hammer in to drive them out ..
I had to cut mine with a torch. Warning, it gets smokey quick. QA1 sells a complete set of replacement cam bolts for 30 bucks.Any tips on removing the upper control arm cam bolts?.. seems like they are frozen into the bushings, so I cant drive them out of the body mounts because it is hard to get a hammer in to drive them out ..
theyve gone up in price then since I ordered mine last year. my bad.Wrong, not so.
They are $50.00, on their web site page.
If you're reusing these UCAs and replacing ball joints...
Remove the ball joints before you remove the UCAs from the car.
It's a lot easier than than putting them in a vice and less chance of bending them.
