z_daddy
z_daddy
Does anyone know if there is any difference in 68 - 74 A arms beside the ball joints ( shape, size length)
Thanks, wasn’t sure cause I bought these inserts for the spindle that allows you to keep small ball joints, but wheels are out of wack ( alignment)The ball joint size is the only difference, the dimensions are the same otherwise
ThanksThe ball joint size is the only difference, the dimensions are the same otherwise
