1. Bodyperson
    Bodyperson Pedal to the metal FABO Gold Member
    6,857
    9740
    Nov 26, 2015
    NW MONTANA
    Local Time:
    2:49 PM
    Well quote me next time... jackass. Just trying to play
  2. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    78,136
    55742
    Jun 7, 2010
    Georgia
    Local Time:
    4:49 PM
    lol. I wasn't trying to be all that man. I was simply lettin you know how I want to do it, that's all.
  3. Bodyperson
    6,857
    9740
    Nov 26, 2015
    NW MONTANA
    Local Time:
    2:49 PM
    Ha. And you did quote me. A little slow tonight. Just didnt get it
  4. RustyRatRod
    78,136
    55742
    Jun 7, 2010
    Georgia
    Local Time:
    4:49 PM
    S'ok. I'm always slow.
  5. Bodyperson
    6,857
    9740
    Nov 26, 2015
    NW MONTANA
    Local Time:
    2:49 PM
    And I usually try to be the stickler of the OP. Calling people out. Now who is the Jackass. Lol
  6. RustyRatRod
    78,136
    55742
    Jun 7, 2010
    Georgia
    Local Time:
    4:49 PM
    Happens to the best of us! lol
    • Agree Agree x 1
    • Kendog 170
      Kendog 170 Let the boy go !
      2,360
      1685
      Mar 10, 2016
      Tewksbury Ma.
      Local Time:
      4:49 PM
      Did you say please ???:lol:
      • Like Like x 1
      • RustyRatRod
        78,136
        55742
        Jun 7, 2010
        Georgia
        Local Time:
        4:49 PM
        Naw, that shows weakness. lol
        • Like Like x 1
        • Professor Fate
          Professor Fate Push the button, Max...
          2,271
          3022
          Jan 13, 2020
          Wisconsin
          Local Time:
          3:49 PM
        • MileHighDart
          MileHighDart Well-Known Member
          4,425
          4206
          Jun 3, 2004
          Lakeview, OR
          Local Time:
          9:49 PM
          I have the QA1 small ball joint upper arms on my Dart. I was able to get up to 6 degrees of caster with them.
          • Like Like x 1
          • Ricks70Duster340
            Ricks70Duster340 Child of the King, widower FABO Gold Member
            613
            402
            Feb 8, 2021
            Sisterdale, TX
            Local Time:
            3:49 PM
            I will be installing the QA1 UCA's with big balljoint as I upgrade my car from SBP to BBP. Please remind me: I will have 24:1 manual steering with 15x7 wheels and 215/60/15 up front. Would the best caster setting be larger than the Skosh Chart shows when I am looking for a balance of ease of steering & high speed stability?
          • 72bluNblu
            72bluNblu FABO Gold Member FABO Gold Member
            11,744
            6535
            Nov 28, 2008
            NorCal
            Local Time:
            1:49 PM
            Yes. So, in keeping with the categories on the SKOSH chart, I would say you can add +2° to the recommendations listed for the caster, keeping everything else the same. For example, “granny” would be -.25° camber, +3.5° caster, 1/16 to 1/8” toe in. “Max perf. street” goes to -.75 to -1° camber, +4.5° to +5.5° caster, etc.
            With the QA1’s +5° will probably be about the maximum you can get anyway, although it will depend on your ride height and the alignment specifics on your car.
            • Thanks! Thanks! x 1
            • Demonracer
              Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
              5,201
              3234
              Jan 31, 2010
              Cleveland, Texas
              Local Time:
              3:49 PM
              RRR, you can go to Classic, PST & some of the other suppliers & they will send a catalog for those of us who are internet challenged. LMAO
              • Like Like x 1
              • OllieDemon45
                OllieDemon45 Active Member
                38
                10
                Apr 5, 2021
                Mid Michigan
                Local Time:
                4:49 PM
                Are the control arms still available?
              • 512Stroker
                512Stroker We are all here because we are not all there.
                3,032
                2381
                May 30, 2016
                Freedom, MO
                Local Time:
                3:49 PM
                Last fall I tried to locate a set and no one had any in stock and could not tell me when they would be in. So I went with the QA1 uppers and boxed the LCA's and it worked out very well. Caster is now set at +4.5
                • Like Like x 1
                • RustyRatRod
                  78,136
                  55742
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  4:49 PM
                  They're sittin in my dining room.
                  • Like Like x 1
                  • RustyRatRod
                    78,136
                    55742
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    4:49 PM
                    That's what I'm going to do with mine when I finally get there.
                    • Like Like x 2
                    • 512Stroker
                      3,032
                      2381
                      May 30, 2016
                      Freedom, MO
                      Local Time:
                      3:49 PM
                      FYI, I boxed the LCA's and used PST poly bushings with their greaseable spindles.
                      Made a noticeable difference.
                    • RustyRatRod
                      78,136
                      55742
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      4:49 PM
                      I don't know what I'm gonna do on the lower bushings yet. I have some Prothane poly bushings. I think what I am going to end up doing is using those on the stock pins. I wanted the Delrin stuff from Bergman, but I am going to really have to make this budget friendly at this point.
                      • Agree Agree x 1
                      • cudamike13
                        cudamike13 cudamike13 FABO Gold Member
                        612
                        530
                        Sep 19, 2010
                        Mineral Bluff Ga
                        Local Time:
                        4:49 PM
                        Sorry, their gone.
                      • Bryan Lohmiller
                        Bryan Lohmiller Active Member
                        37
                        1
                        Nov 5, 2020
                        Elk Grove, CA
                        Local Time:
                        1:49 PM
                        what brand of UCA's do people recommend on here was looking at CPP and QA1's and what brands offer's the most caster built into them that are not fully adjustable with big ball joints
                      • BergmanAutoCraft
                        BergmanAutoCraft FABO Vendor FABO Vendor
                        259
                        200
                        Feb 18, 2013
                        Long Island, NY
                        Local Time:
                        4:49 PM
                        All the fixed designs are all the same in terms of extra caster. The QA1 is the nicest of that type.
                        However, with the other options, those arms are obsolete.
                      • Bryan Lohmiller
                        37
                        1
                        Nov 5, 2020
                        Elk Grove, CA
                        Local Time:
                        1:49 PM
                        OK so how does the PST ones compare to the QA1 and how much do you want for the QA1's with the small ball joint?
                        and yes I know my first question was about the big ball joints
                        I was planning on going with the PST LCA rebuild kit.
                      • Ironracer
                        Ironracer Gearhead
                        1,575
                        1017
                        May 8, 2020
                        Tampa Bay Florida
                        Local Time:
                        4:49 PM
                        I was gonna do the Delrin also but went rubber. Offset uppers and the now obsolete moog problem solver strut rod bushings
                      • BergmanAutoCraft
                        259
                        200
                        Feb 18, 2013
                        Long Island, NY
                        Local Time:
                        4:49 PM
                        I don’t know what PST offers. My opinion was based on hands on fitment, consistency in alignment numbers and the gusseting and amount of material around the upper ball joint.
                        QA1 Upper Control Arm - Bergman Auto Craft
