daves66valiant
68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
Okay so Im really close to having everything ready for the /6 to 340 conversion. I ended up keeping the /6 a/c 22in radiator from the car since it was in really good shape and my lower radiator hose would work out fine (70s aluminum water pump style) The upper is another issue since a 68’ V8 radiator inlet resides on the opposite/drivers side.
If still using the /6 radiator, has anyone done this before and what upper radiator hose did you use.
Please. I already know about the coat hanger trick and take it to the parts store. Been there done that. Parts stores suck *** these days. All of them practically.
If anyone has a Gates or other part number that would work I’d be grateful. I may end up cobbling something together but I’d like it to “lookl legit OE if possible
