Upper vent wing pivots
moparfanatic56
0quawka, il
Not sure if this is the right forum for this but does anyone know if the upper vent wing pivots are the same for an A body and a B body. I can find them for a B body but not an A body. I really only need the grommets or seals (whatever they are called) that goes through the hole in the vent glass, is there a source for those out there anywhere, I have looked but not having any luck. Thanks for any info.
following... i need some of those grommets also....Rich
Browse the plumbing department of a good hardware store for tap and valve seals. I've found some in the past that did the trick.
I kinda guessed on that but they will not sell the grommets separately.
Did you come up with anything on this? I bought some supposed NOS upper pivots with gaskets and tried to install them last night. The pivots are wrong and they came with 4 inner gaskets. I can reuse my original pivots but I need to figure something out for the outer gaskets that fit into the glass.
I used these and a short piece of vacuum hose:
Seals Vent Window Pivot 67-72 A Body & 66-70 B Body
