USPS Strikes AGAIN!!
General Discussion
  1. AlaskaJeff
    AlaskaJeff Well-Known Member
    308
    523
    Nov 5, 2020
    Palmer, Alaska
    Local Time:
    10:48 AM
    SOMEHOW it didn't get damaged :realcrazy:
    I heard the delivery driver gently set the package on my porch and run off before I could get to the door........ Box.jpg
  2. Car Nut
    Car Nut Mopar Master
    8,212
    53006
    Dec 28, 2018
    Trump Train
    Local Time:
    12:48 PM
    At least it showed up.
    • Agree Agree x 1
    • ragtopfury
      ragtopfury Well-Known Member
      3,122
      2977
      Jul 14, 2011
      Manchester, MD
      Local Time:
      2:48 PM
      Was the part damaged?
      Not saying the usps couldn't be more gentle at times, but a lack of packing material also allows parts an attempted escape.
      Jake ordered an output shaft for his truck. An empty box arrived with a 2 inch hole punched out of 1 corner. Only thing in the box was the plastic bag the shaft had been in.
      • Agree Agree x 7
      • Like Like x 1
      • Righty Tighty
        Righty Tighty FABO Gold Member FABO Gold Member
        1,228
        1018
        Aug 16, 2019
        Sahuarita, AZ
        Local Time:
        12:48 PM
        I agree with @ragtopfury . For something like that to happen, it most likely was the fault of whoever packed it for shipping. You can't just put something in a box and send it on its way. I slide in extra layers of cardboard to make the walls of the box thicker and fortified, then wrap my item, sometimes putting it inside a smaller box, then cushion it.
        You should be able to shake the box vigorously and not feel your item move within. This person obviously did not do that.
        • Agree Agree x 6
        • Like Like x 1
        • halifaxhops
          halifaxhops It's going to get stupid around here! FABO Gold Member
          69,589
          39984
          Jan 20, 2014
          Hoppyworld, PA
          Local Time:
          2:48 PM
          I have to watch when I do distributors. I actually got one the shaft was bent 30 degrees sticking out. Crazy how it bent a hardened metal 1/2" shaft!
          • Agree Agree x 3
          • gzig5
            gzig5 FABO Gold Member FABO Gold Member
            1,938
            2258
            May 3, 2018
            Mequon, WI
            Local Time:
            1:48 PM
            The box doesn't look overly damaged, that is on the packer.
            I've worked in multiple bulk mail centers, as well as fed ex and UPS. The fact that most of the packages get where they are going without being crushed to dust never ceases to amaze me. It is not a gentle process and anything of value needs to be packed with that in mind.
            • Like Like x 1
            • Agree Agree x 1
            • WV64Signet
              WV64Signet FABO Gold Member FABO Gold Member
              1,810
              2344
              Aug 6, 2021
              Hampshire County, WV
              Local Time:
              2:48 PM
              I'll agree on the packing comment.
              Having been the victim of how the package movement system operates, depending on how many times that box was moved from one container to another across multiple modes of transportation and distribution centers....it's tough.
              Immobilizing the part inside the box is the only way to increase the likelihood of things like that occurring. I hate getting a relatively fragile part in a too-big box accompanied by a single piece of brown paper. Recipe for disaster.
              EDIT TO ADD
              I'm wondering how Priority Mail and the "need for speed" actually increases the pummeling of the package through the system?? Any thoughts @gzig5 ?
              • Like Like x 1
              • Agree Agree x 1
              • pishta
                pishta I know I'm right....
                21,449
                10830
                Oct 13, 2004
                Tustin, CA
                Local Time:
                11:48 AM
                Put the item in a box and then pack the rest of the box with sealed empty plastic water bottles, weigh nothing and are very durable. Let the air out of a few if the box wont close. And ALWAYS put the delivery address on the part itself inside the box in case it sides out. like maybe a little wired card or stuff it in the housing. USPS will find the part on the ground under a conveyor or at the bottom of a tote and not have a clue where its going. It will end up in Atlanta Lost parcel warehouse for pallet auction after 90 days or something like that.
                • Like Like x 4
                • Righty Tighty
                  1,228
                  1018
                  Aug 16, 2019
                  Sahuarita, AZ
                  Local Time:
                  12:48 PM
                  Love the water bottle idea.
                  • Agree Agree x 1
                  • gzig5
                    1,938
                    2258
                    May 3, 2018
                    Mequon, WI
                    Local Time:
                    1:48 PM
                    The packages all see the same transport apparatus through the buildings. It's moving as fast as they can, but in my experiences most of the damage comes from the diverters and collection areas. The diverter technology is getting better each year. I think the "Speed" in Priority mail mainly comes from logistic prioritization. Those boxes get on the truck first.
                    At this time it doesn't matter. they don't have enough trucks or drivers. I've sent two packages priority in the last month, both should have taken 2-3 days but took 12-14. You can't get blood from a turnip, but you still are paying for the higher level of service.
                  • hosehead
                    hosehead Well-Known Member
                    1,177
                    972
                    Dec 4, 2008
                    Grand Lake o the Cherokees
                    Local Time:
                    11:48 AM
                    As a former employee, I can tell you that negative space in the box is the biggest enemy. I am not forgiving the post office for a bunch of its ineptitude but that box in the pic is poorly packed.
                    People forget that the sorting system is machinated. Its easy to blame the employees but the majority of damage like that is caused by poor packing when it goes through the sorting machines. Not trying to pass the buck but its true.
                    That box could have been at the bottom of a wire bin that had hundreds of pounds of other boxes on top of it. All done via machines. Just one dudes opinion.:mob:
                    • Agree Agree x 4
                    • WV64Signet
                      1,810
                      2344
                      Aug 6, 2021
                      Local Time:
                      2:48 PM
                      Appreciate the insights from those who have been part of the system.
                    • gunbunny
                      gunbunny Well-Known Member
                      3,235
                      2190
                      Apr 14, 2009
                      Cincinnati, OH
                      Local Time:
                      2:48 PM
                      I was a city carrier for the USPS for several years.
                      The OP made the statement the carrier ran off before he could get to the door. The question I have is, what if you would have caught him? Do you seriously think the carriers do this stuff?
                      Don't get mad at the carrier, they very likely got the package damaged.
                      I can't tell you the number of times I received a damaged parcel, I didn't damage it, but I had to deliver it.
                      I've been screamed at by people for it though. Those people usually ended up picking their mail up at the post office for a few weeks.
                      • Agree Agree x 4
                      • Like Like x 1
                      • pishta
                        21,449
                        10830
                        Oct 13, 2004
                        Tustin, CA
                        Local Time:
                        11:48 AM
                        if you get handed a blown out package, can you just refuse it? Return to sender jacked up. Blown out box and all in a sealed bag. I sent a crank in a crankshaft box (received a Eagle forged it it) and FedEx dropped it on its end off a dock or something, broke the flange between two bolt holes. Buyer told me it was damaged in transit, sent pics. I told the guy to just put it back on the doorstep and I sent Fedex back to pick it up as damaged in transit. They sent it back to me no charge and cut me a check for breaking it. Took 3 months and a call to my high school friend who was a ramp manager (about as high as you can go in the field with Fedex) and I got the check 4 days later...sent Fedex priority! They are my go to shipper as they seem to have it perfected. I sent a shipment to North Carolina and realized I sent the wrong lot so I called Fedex in a panic and told them my mistake. "No problem, we will just reroute it to its proper destination..."! The next hop, it got a new shipping label affixed and it was on its way. That is how you do it Fedex! Now just dont drop it!
                        • Like Like x 1
                        • LO23M8B
                          LO23M8B Well-Known Member
                          1,465
                          739
                          Jan 30, 2019
                          Michigan
                          Local Time:
                          11:48 AM
                          My biggest problem is everyone wants to send everything in a if it fits it ships. Just to damn expensive most of the time. I just don't buy a lot of stuff because of this.
                        • gunbunny
                          3,235
                          2190
                          Apr 14, 2009
                          Cincinnati, OH
                          Local Time:
                          2:48 PM
                          If it comes from USPS, you sure can. Just don't open it!
                          If you open it, then you have to pay for return shipping.
                        • AlaskaJeff
                          308
                          523
                          Nov 5, 2020
                          Palmer, Alaska
                          Local Time:
                          10:48 AM
                          To be clear, I am NOT blaming the carrier at all. I KNOW he, more than likely had nothing to do with the condition of the package by the time it got to my house. It just would have been good to talk to him about what he knew of how it came to be that way. The part in question was a cable for a B&M shifter. It was packed decently in the box, and the cable was zip tied up in a circle for shipment. Everything else in the box looked fine. Somehow that one end just decided it needed to poke it's head out.
                        • harrisonm
                          harrisonm Well-Known Member
                          3,633
                          3940
                          Jan 16, 2005
                          Topeka, KS
                          Local Time:
                          7:48 PM
                          I will TOTALLY agree with the folks who have already suggested that the problem was with the packing. A poorly packed item has little chance of being delivered without either damage to the box, item or both. In all the hundreds of things I have sold and shipped, I always over-packed everything.
                          • Agree Agree x 1
                          • 4spdragtop
                            4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
                            32,476
                            13584
                            Aug 28, 2009
                            Wasting time here
                            Local Time:
                            1:48 PM
                            What I love reading is how cylinder heads or heavy assed shit gets packed into flat rate boxes, then people bitch and complain that shipping prices are so high....OR that they get a pkg damaged lol. If I worked for USPS.....lmao
                          • AlaskaJeff
                            308
                            523
                            Nov 5, 2020
                            Palmer, Alaska
                            Local Time:
                            10:48 AM
                            I will NEVER complain about Flat Rate prices. Living in Alaska shipping is a HUGE deal when ordering anything. Fortunately USPS Flat Rate are the same $$ price to AK & HI as they are to any of the Lesser 48 states, so that is what I try to use 99% of the time when having stuff shipped here. I've lived here since 91 and have heard it all related to shipping to AK when dealing with companies and sellers.
                            • Agree Agree x 2
                            • inkjunkie
                              inkjunkie Well-Known Member
                              17,317
                              2812
                              May 24, 2009
                              Local Time:
                              11:48 AM
                              As a retired USPS employee I can safely say that is not the fault of the USPS. If items are not correctly packaged damage is going to happen. Open air spot=crush zone. Levers like what is protruding....shipper needed to line the box with solid stylofoam, place item in the center and stuff the shit out of it with peanuts. The USPS handles very little, if any, mail by hand. Thus video is of the APPS machine. It process all parcels at some time during their trip. Often times on both ends. Lets just say that your package was the first to be kicked off into one of those cardboard bins. What do you think will happen to your package, with that lever only being protected by a single layer of cardboard, when a 69.9 pound package lands on it? I always tell people you want to make sure your item is packed safely. Throw it across the room. Play soccer with it. Drop it from 8' in the air. I have posted time and time again how to assure your packages/letters arrive safely...but then again nobody reads my post so...
                              Christmas is coming. Heavy Monday is only a few weeks away. Please keep in mind that I set this record back in 2006...and from what I have been told it still stands today. In a 6 hour period I ran over 250k first class letters thru an AFSC...the stamp cancelling machine. Closest operator was 75k letters behind me. Know what caused the one or two jams I had during that time? Envelope flaps not taped shut, in particular the ends. There are at least a dozen or so gates in the machine These gates are high speed letter openers. Letters are not even an inch apart as they go hauling ass by these gates. One letter with loose flaps often takes out 30-35 letters behind it. Do not mail a stack of pictures. The in/shing will not so politely tear open your envelope and then feed the pictures individually into the feeder. Some will come out the fine cull, some will get shredded in the machine and others will end up in the reject bin. Now if the envelope ends up on the floor your images go right into the trash. Hey...I only worked there for 20 or so year so what the hell do I know..
                              The USPS used to offer tours to the public. But ever since the Bio Hazard systems were put in after the anthrax attacks they stopped. For some reason many members of the public think their letters are getting worked by hand by a clerk sitting in a case....they are not. Nor is your parcel getting handled by a human. Many pieces of mail do not get touched by a single human until they make it to their destination delivery station. Hell, when the old feed system was torn out and replaced by "Barney"...around the same time the BDS units were installed...letters from 9-10 years prior were found it the feed system....#weldthedoorsshut
                              • Thanks! Thanks! x 1
                              • inkjunkie
                                17,317
                                2812
                                May 24, 2009
                                Local Time:
                                11:48 AM
                                This is the very reason I silently backed out of smoking/shipping cheese. A friend wanted to try it. 2 pounds of cheese cost me $9 at Costco and $19 to ship it...
