1. jau126
    jau126 '65 Dart GT 273 904
    136
    67
    Jun 7, 2020
    Salt Lake City, UT
    Local Time:
    9:59 PM
    Looking for any members in the Utah. I am looking for a good machine shop and head porters.
    I have heard stories around SLC while I am out about a few Barracudas so hopefully they/you are on here.
  2. dgibby
    dgibby Well-Known Member
    1,066
    527
    Aug 23, 2012
    utah
    Local Time:
    9:59 PM
    I used American Cylinder head in Salt Lake to freshen up a 340 for me. There was an old timer there that really knew his stuff. Its been awhile so I don't know if he is still there.
    I had Jensen Machine in Ogden build a 408 short block for me recently and they did a great job.
    I've also heard of shop in Utah County called Strasburg Machine that is supposed to be a mopar shop. Have never used them so not sure about them.
    • Thanks! Thanks! x 1
    • Cudabnu
      Cudabnu (3) 64 Val Verts. /6 4spd, 273/904, 318/727
      400
      466
      Mar 4, 2019
      Moorpark, CA
      Local Time:
      8:59 PM
      A buddy of mine into mopars says he uses C&T in Orem
      • jau126
        136
        67
        Jun 7, 2020
        Salt Lake City, UT
        Local Time:
        9:59 PM
        Did Jensen just assemble or also do some machining? I have a 273 that needs work that would be easiest just to pull the motor so it might get a full refresh and hipo pistons.
      • Car Nut
        Car Nut Mopar Master
        18,330
        76842
        Dec 28, 2018
        Trump Train
        Local Time:
        9:59 PM
        I live 20 mins from Jensen in Northern Utah, they assemble and machine blocks.
        I'm looking for a good trans shop.
        • Disagree Disagree x 1
        • dgibby
          1,066
          527
          Aug 23, 2012
          utah
          Local Time:
          9:59 PM
          Both. I supplied the block and rotating assembly and the did the machine work and assembled it.
        • dgibby
          1,066
          527
          Aug 23, 2012
          utah
          Local Time:
          9:59 PM
          Not sure on a trans shop..
          I called around for my 727 and either got a crazy quote or you could tell that they didn't know what they were doing. Ended up doing it myself, not as bad or scary as you might think.
