Vacumn advance can adjustment screw, info please.
Electrical and Ignition
  1. 340doc
    340doc Well-Known Member
    2,620
    913
    May 8, 2010
    Hollywood Fl
    Local Time:
    2:21 AM
    From what I've heard it doesn't change the amount of advance, just the rate. Is this so? Also which direction of adjustment does what? Thanks.
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    49,390
    34159
    Jan 18, 2006
    Iowa
    Local Time:
    1:21 AM
    • Like Like x 2
    • 340doc
      2,620
      913
      May 8, 2010
      Hollywood Fl
      Local Time:
      2:21 AM
    • Murray
      Murray FABO Gold Member FABO Gold Member
      1,700
      1100
      Apr 19, 2010
      San Jose, California
      Local Time:
      11:21 PM
      The inside allen screw adjustment changes the rate of advance, or how sensitive the diaphragm responds to the vacuum. Been a long time, but I think if you turn the screw in or clockwise, it reacts faster, is more sensitive, advances sooner. The reverse would happen in the counter-clockwise direction. Someone can correct me if I got that wrong.
      • Thanks! Thanks! x 1
      • Agree Agree x 1
      • Dana67Dart
        Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
        4,295
        2616
        Jul 16, 2017
        Northern Colorado
        Local Time:
        12:21 AM
        The rate is set by the spring rate and the total advance is set by the stroke. The pre-load or lack there of just sets the amount of vacuum it takes to start moving the diaphragm. The screw only adjusts the pre-load
        I have had some ford vacuum advance cans that you could screw off the end and replace the spring and the stop thus adjusting the rate and the total amount, pre-load was set with a spacer under the spring.
        • 340doc
          2,620
          913
          May 8, 2010
          Hollywood Fl
          Local Time:
          2:21 AM
          The advance seems to come in real quick on our 70 slant, causing it to ping. I watched it with a light. I'm hoping it has some adjustment available counter clockwise to slow it down a bit. Appreciate all your comments.
          • Like Like x 1
          • Murray
            1,700
            1100
            Apr 19, 2010
            Local Time:
            11:21 PM
            Just a heads-up. Not all vacuum advances are adjustable.
            • Agree Agree x 2
            • 340doc
              2,620
              913
              May 8, 2010
              Hollywood Fl
              Local Time:
              2:21 AM
              Thanks, I'm aware.
            • halifaxhops
              halifaxhops It's going to get stupid around here! FABO Gold Member
              59,151
              27435
              Jan 20, 2014
              CENTRURAL, PA
              Local Time:
              2:21 AM
              Look at the number on the arm also you might have a high one that was changed at some point. Know the distrib number I can look it up.
              • Like Like x 1
              • toolmanmike
                49,390
                34159
                Jan 18, 2006
                Iowa
                Local Time:
                1:21 AM
                Single point or electronics are "usually" adjustable. Most dual points are not.
              • halifaxhops
                59,151
                27435
                Jan 20, 2014
                CENTRURAL, PA
                Local Time:
                2:21 AM
                If a 3/32 allen fits in it is adjustable. Mike you can do the older dual points with springs and shims silly!
                • Agree Agree x 2
                • Murray
                  1,700
                  1100
                  Apr 19, 2010
                  Local Time:
                  11:21 PM
                  Another issue- the new repo BB vacuum advances do not indicate the amount of advance. My original on a 383 indicates "10.5" which is higher than most. Am reluctant to purchase these because of that. What do you boys think?
                • toolmanmike
                  49,390
                  34159
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  1:21 AM
                  I knew that but what a pain compared to a Allen wrench. LOL
                • 340doc
                  2,620
                  913
                  May 8, 2010
                  Hollywood Fl
                  Local Time:
                  2:21 AM
                  Thanks, if adjusting it doesn't help me I'll pull the dist and get the number. I do recall seeing a tag on it.
                • halifaxhops
                  59,151
                  27435
                  Jan 20, 2014
                  CENTRURAL, PA
                  Local Time:
                  2:21 AM
                  Probably a remanufactured unit then, one of the problems with them they set a curve so it works on a lot of applications, some good some bad. Never come with a number for obvious reasons.
                • AJ/FormS
                  AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                  18,208
                  6456
                  Jan 19, 2014
                  South-Central Manitoba,Canada, 900ftelevation
                  Local Time:
                  1:21 AM
                  You can figure the number out real easy, just set it loose, install it, evacuate the chamber and read the timing change. Badabing.
                  If you screw it in until it is really,really slow, on mine, it began to limit the amount.
                  You can modify the total by filing the stops. I run as much as possible because she needs the timing at cruise rpm to make the gas-mileage.
                  A slanty pinging? How much initial? What elevation are you at? What stall and gears?
                  Have you tried Trading away some initial, then bringing the mechanical in faster to compensate.
                  I guess you've tried the usual stuff like intake air temp,AFR, and exhaust.. And solid lifter cams are a little sensitive to the hot-lash. Mine runs pretty good at 013/023 Hot. Not so good at the spec .010/.020.......
                  HappyHotrodding
                • 340doc
                  2,620
                  913
                  May 8, 2010
                  Hollywood Fl
                  Local Time:
                  2:21 AM
                  I'm at 6 initial. All stock slant. 3.23 gear. 12 and 22 on the valves. I'm pretty much at sea level. This all seemed to start when I swapped over to electronic. I really need to investigate the used dist. to see where everything's at, starting with the V-can. Appreciate your input.
                • halifaxhops
                  59,151
                  27435
                  Jan 20, 2014
                  CENTRURAL, PA
                  Local Time:
                  2:21 AM
                  If it was a rebuild from the poarts store it can be anywhere. They are made to fit a whole span of years and applicationws.
                  • Like Like x 1
                  • pishta
                    pishta I know I'm right....
                    17,253
                    6871
                    Oct 13, 2004
                    Tustin, CA
                    Local Time:
                    11:21 PM
                    you can swap out the can, its 2 screws and a optional clip.
                    • Agree Agree x 1
                    • SpeedyEd
                      SpeedyEd Member
                      7
                      4
                      Dec 19, 2014
                      Johnstown,NY
                      Local Time:
                      2:21 AM
                      If you can't use the old vac. advance, try the Crane 99619-1 vac timing limiting plate. It was made for the Delco dist. but it should fit. I have a rebuilt vac unit that was rebuilt but the diaphragm wouldn't seal. But I can't locate it to verify the fit.
                      You could make a stop held by the mounting screw to limit the travel of the plunger.
                      SpeedyEd
