Vacuum Diagram
Slant 6 Engines
  1. Lost Bushman
    Lost Bushman Rich with Anti-Money
    156
    9
    Sep 26, 2008
    Lexington, South Carolina
    Local Time:
    3:45 PM
    So I just bought a '72 Swinger Special that has the 225 /6 in it. It's a runner until I finish my Magnum headed 360 for it. The 6 runs ok, but there's a lot of bare vacuum connections in the engine bay. Not to mention that I found the vac canister in a shoebox in the trunk.....
    Can anyone point me to a routing diagram for the vac lines for this car? Haynes and Chilton have failed me.
  2. Lost Bushman
    156
    9
    Sep 26, 2008
    Local Time:
    3:45 PM
    Nobody? Really?
  3. Lost Bushman
    156
    9
    Sep 26, 2008
    Local Time:
    3:45 PM
    Wow, ok then.
  4. lowbudget
    lowbudget Mopar Man
    452
    43
    Jun 21, 2008
    Vernal Utah
    Local Time:
    1:45 PM
    I have a 75 but I don't think that would help you. You might try over at slantsix.org
  5. Gnome
    Gnome Well-Known Member
    580
    4
    Aug 3, 2010
    fredericksburg,va
    Local Time:
    3:45 PM
    this is for a 1975 but it may get you started on where some of the lines actually go
    [​IMG]
    HTH
    G
  6. 73goldduster
    73goldduster Well-Known Member
    72
    1
    Jan 23, 2007
    santa cruz, ca
    Local Time:
    12:45 PM
    i would think that as long as the vacuum advance for the dist was hooked up it should be ok. just cap the open ports. post some pics!
    i remember a line from the intake manifold to airfilter housing, also another one from carb to same.
    when i got my /6 duster there were a few capped lines, a few open lines. the vacuum modulator thing had a broken toothpick jammed into one of the ports...
  7. Lost Bushman
    156
    9
    Sep 26, 2008
    Local Time:
    3:45 PM
    Thanks guys!
