Dear Mopar Guys,
I have a question abouting of the vacuum hoses. In the Plymouth Barracuda Service Manual 1966 on Site 14-71 is a description about the Distributor Vacuum Control Valve .
Here are all three ports described. In my case only the Port to Manifold is loaded. The port to Distributor is closed with an plug, the port to the Carb is open.
The Distributor vacuum hangs direct on the Carb.
Original Distributor and Carter BBD 1-1/4 are installed.
Is this setup correct, or is the hose routing wrong??
Kind regards
Bernhard
Kind regards
Bernhard
