Valiant will not start. Help!
Electrical and Ignition
  1. ValiantV8
    ValiantV8 1964 Plymouth Valiant Signet V-200 Convertible
    20
    14
    Mar 19, 2019
    Georgia
    Local Time:
    12:07 PM
    I have a 1964 Plymouth Valiant V200 Signet, I was out driving a few days ago and after leaving a stop light, the car stalled and then would not crank again.
    The gauge states that there is 3/4 a tank of gas in it (though I wouldn't rule out the gauge is wrong) so I went to the station and got 2 gallons of gas to put in it.
    Although the battery stated it had 13 volts, I attempted to jump the car off to see if that would work.
    I have been having problems with the wiring coming disconnected from the ignition switch, so I looked and reconnected those.
    The car still will not start.
    Any ideas on where I could go from here?
    -posted this on the Fuel and Air Filters Forum as well.
  2. JDDart
    JDDart Active Member
    27
    5
    Apr 12, 2019
    North Carolina
    Local Time:
    12:07 PM
    My 69 Dart just had the same thing. It turned out it was the ground wire at the battery. Is it cranking? Or dead? Gas and spark
  3. ValiantV8
    20
    14
    Mar 19, 2019
    Georgia
    Local Time:
    12:07 PM
    the car makes no noise when the key is turned however, the radio and lights come on
  4. Mikes270dart
    Mikes270dart Well-Known Member
    340
    73
    Sep 26, 2010
    Toronto
    Local Time:
    11:07 AM
    Jump the solenoid, see if the starter engages. If so run a hot wire to the coil, jump the solenoid and it should start. If it does start then you know the problem is between the key and the solenoid
    • Like Like x 1
    • Dave NEO
      Dave NEO Well-Known Member
      1,000
      236
      Jan 6, 2017
      midwest
      Local Time:
      10:07 AM
      wires to starter, fuses,...check you connected those loose switch wires back correctly. connections on starter relay on fendewell..
      • Thanks! Thanks! x 1
      • Slantsix64
        Slantsix64 Well-Known Member
        2,675
        1043
        May 11, 2014
        SGV
        Local Time:
        11:07 AM
        Have your key on the run position. then get a screw driver and bump the starter relay see if it starts like this. Also put it in Neutral and try to start
        • Dave NEO
          1,000
          236
          Jan 6, 2017
          midwest
          Local Time:
          10:07 AM
          • Dave NEO
            1,000
            236
            Jan 6, 2017
            midwest
            Local Time:
            10:07 AM
            so ...any luck?
          • ValiantV8
            20
            14
            Mar 19, 2019
            Georgia
            Local Time:
            12:07 PM
            ground wire to the battery is good, i have the part pictured in the comments, but am waiting on a new ignition switch so i can install them at the same time. so not yet.
            • ValiantV8
              20
              14
              Mar 19, 2019
              Georgia
              Local Time:
              12:07 PM
              I found the problem. The last time I reconnected the wires to the ignition switch, I connected them incorrectly. Switch the connection on one wire and it started right up. Thanks for your reply and advice.
            • Dave NEO
              1,000
              236
              Jan 6, 2017
              midwest
              Local Time:
              10:07 AM
              YES!
              • Like Like x 1
              • mycuda
                mycuda FABO Gold Member FABO Gold Member
                5,825
                3177
                Feb 15, 2011
                Chicago/ Metro
                Local Time:
                11:07 AM
                Hero
                • Like Like x 1
                • ValiantV8
                  20
                  14
                  Mar 19, 2019
                  Georgia
                  Local Time:
                  12:07 PM
                • Dave NEO
                  1,000
                  236
                  Jan 6, 2017
                  midwest
                  Local Time:
                  10:07 AM
                  had a '63 V-100 back around 1971. Back then they were pretty done when they had 8 mid-west winters on them. It was best 250.00 car I ever had..
                  • Like Like x 1
