Valley pan for Stage VI heads
Discussion in 'Big Block A body Tech' started by Garys72Duster, Jan 11, 2019.
  1. Garys72Duster
    Garys72Duster Well-Known Member
    273
    145
    Apr 23, 2017
    Brighton, Co
    Local Time:
    1:07 AM
    I have some ported Stage VI heads I want to try out. The spacer has a thin recess cut into it, for a valley pan. Then you use paper gaskets on top where the intake manifold meets the spacer. So is there a special valley pan that will work on there? Or do I just cut the intake port portion off a stock valley pan?
  2. Dana
    Dana FABO Gold Member FABO Gold Member
    817
    366
    Oct 20, 2011
    Calcutta OH
    View My Photos
    Local Time:
    3:07 AM
    Hughes used to sell one, but it could use a stiffener welded down the center.
    • Thanks! Thanks! x 1
    • PRH
      PRH Well-Known Member
      136
      98
      Dec 14, 2018
      So. Burlington, Vt
      Local Time:
      3:07 AM
      I just used a piece of sheet metal(aluminum) cut/trimmed to size, and just had the sides bent up a bit to conform to the heads.
      If you don’t drill and tap a few extra holes to physically “mount” the spacers to the heads(socket head screws in recessed holes), then technically you’d want to run gaskets on either side of the spacer.
    • oldkimmer
      oldkimmer Well-Known Member
      9,593
      900
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      2:07 AM
      On my 470 stroker it is a sheet of aluminum that bolts down with the front and rear rail bolts. I seal it with rtv or the right stuff depending which I have on hand. I’ll see if I got a pic. Kim
    • Garys72Duster
      273
      145
      Apr 23, 2017
      Brighton, Co
      Local Time:
      1:07 AM
      I have already drilled, and countersunk the spacers and tapped the heads. Bolted spacers to the heads with allen head screws. I guess I will need a thin film of silicone between the 2? There are locator pins on the spacers for proper alignment. Then I can just trim the port area off a stock gasket, and put that on before the spacer. Then use paper gaskets at manifold to head. Here's a few pics of the head showing the gap for the valley pan, and the bolts.
