Sure
This little gizmo was added to 71 and later VBs to allow you to kick down the trans one gear without flooring it like you more or less had to do on older VBs.
This is a nice feature to have;
1)with low-performance gears in traffic,and with a low-stall OEM TC; when you just want a little better acceleration, and don't need 100% power from the engine.
2) It's nice for merging into traffic at higher speeds and with more power, cuz once downshifted, you can still control the power required to merge, with throttle position, but again, you didn't have to floor it.
3) It makes the Part Throttle 2-3 lift-foot upshift a little softer. I don't see this listed as a function of that device, but it's just my observation.
As you can see all these are for comfort in a DD.
In the 70 and older VBs the KD feature mostly required the gas pedal to be fully or nearly fully depressed before KD became available.
For track-work I see no advantage to this gizmo...... but the 71up VBs are the culmination of decades of fine-tuning from Chrysler, they have all the best features and none of the later super mushy tweaks, which, if you install a shiftkit will be neatly defeated anyway.
