Valve Cover Gaskets for Fabbed Aluminum
streetdak
Cypress, Texas (Houston)
Now that I've gotten a few miles on the car, I still seem to have a valve cover leak. Thanks to the great new technology of smart phones, I confirmed it! Question is now, whats a good gasket to use on these valve covers that seal well? I going to tighten them up a bit more to see if it remedys the problem, but was wondering if anyone else on here has had luck with other gaskets?
BTW im using some fel-pro hard black rubber gaskets from a 85 dodge 318 truck if that helps. Oh and FYI, seems to be bad when 3/4-full throttle, otherwise, dosn't leak
This made me look for ventilation, do you have and crankcase ventilation? I don't see a PCV or a breather cap.
Just a thought.
Just a thought.
Yeah, I though of that too, but that chrome circle on the pass side is a breather, so It does have one. It could be leaking at lower rpm's, its just not as noticeable, maybe a PCV is the way to go
I have the same valve covers on my racecar. I have the Fel-Pro 5/16 thick gaskets to help clear the intake runners. I used black silicone to glue them to the covers & let it set up.
They have been on the engine for three years.
I check valve clearance about three times a year.
No leaks yet, I run an open breather in both valve covers.
ive heard the moroso vc gaskets with the steel in them are a good choice also when my felpros start to leek i will change to the morosos
