Valve lash question?
Discussion in 'Small Block Mopar Engine' started by carls72dart, Jul 16, 2017.
  1. carls72dart
    carls72dart Well-Known Member
    365
    194
    Dec 31, 2008
    massachusetts
    View My Photos
    Local Time:
    12:25 PM
    Hi Fabo, need your help once again. I have a 340 small block with (273 adjustable iron rockers.) It has a crane .484/.484 hydraulic cam. I heard a little tapping and reset the preload on the lifters.
    Cylinder 7 is the one I have a question on. I backed out the adjusters on both intake/exhaust. As I was setting preload, both screws only turned in a little and preload set too quick. The threads on the adjusters do not go two or three threads in. Preload was gone too fast, compared to all other cylinders.
    I ran a compression check and that cylinder came back at 125, compared to all other cylinders from 160-165.
    Just need to know what I should do now. This is all new area to me. Not running the engine, until I know it's fixed. Have been reading, it could be a burnt valve.
    Any and all help is greatly appreciated. Thank you
  2. Bad Sport
    Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
    34,096
    12748
    Jun 12, 2010
    The Wolverine
    Local Time:
    12:25 PM
    Do the heads have hardened valve seats. Could be a sunk valve maybe?
    • Thanks! Thanks! x 1
    • MOPAROFFICIAL
      MOPAROFFICIAL Well-Known Member
      2,790
      1760
      Jun 1, 2016
      breakwater
      Local Time:
      9:25 AM
      That or bent valves. Low cyl psi on that hole. Unless the 2 are off the lifters cup..
      • carls72dart
        365
        194
        Dec 31, 2008
        massachusetts
        View My Photos
        Local Time:
        12:25 PM
        I unfortunately do not know. I purchased the engine used and was told the heads had a 3 angle valve job done on them. You would think that would be done at the same time. I'm going to look through my paperwork and see what I can find. Thank you
      • carls72dart
        365
        194
        Dec 31, 2008
        massachusetts
        View My Photos
        Local Time:
        12:25 PM
        Bad sport, here is the info I have on the engine:
        1972 340 block bored .30 over with 10.5.1 TRW forged pistons w/moly rings rods resized and bushed w/floating wrist pins and new locks.
        pistons and rods balanced
        arp bolts and crank polished
        clevite 77 crank, cam and rod bearings
        windage tray
        dynagear tru roller timing chain
        crane cam 284/480 degreed
        J heads 3 angle valve job
        Comp cams locks and push rods
        Mopar perf. valve springs and adjustable rocker arms
        Edelbrock torker II intake
      • dadodgekid
        dadodgekid When in doubt... floor it FABO Gold Member
        518
        138
        Nov 25, 2013
        Palm City , FL
        Local Time:
        12:25 PM
        what procedure are you usning for adjusting your lifter preload? There is no "lash" with a hyd cam :)
        • carls72dart
          365
          194
          Dec 31, 2008
          massachusetts
          View My Photos
          Local Time:
          12:25 PM
          Back off adjusters so pushrod has up and down motion. Adjust the adjuster, until no more movement up/down and add a half turn to set preload.
        • carls72dart
          365
          194
          Dec 31, 2008
          massachusetts
          View My Photos
          Local Time:
          12:25 PM
          I now realize I used the wrong terminology, thanks for the correction :) I just updated the original post.
        • JoeSBP
          JoeSBP RLTW!
          1,107
          534
          Jun 16, 2015
          NC
          View My Photos
          Local Time:
          12:25 PM
          Are you rotating the crank to unload them? Not trying to insult you, just to be sure. The whole EOIC etc etc
          • Like Like x 1
          • dadodgekid
            518
            138
            Nov 25, 2013
            Palm City , FL
            Local Time:
            12:25 PM
            OK, are you doing your adjusting with the cam at the bottom of the lift sequence?
            Try this, Its what I do for my .557 Solid cam and works perfect. I stole this from Dragzine! Not my work but it does work perfect everytime!
            When the exhaust valve just begins to open on the first cylinder in the firing order, adjust the intake valve by loosening the adjusting nut slightly while spinning the pushrod until you feel lash in the rocker arm. Tighten the adjusting nut until the slack is taken out of the rocker arm and pushrod. Lightly turn the pushrod with your fingers as you tighten the adjusting nut, and you should feel a point where there is a little resistance (this is called Zero Lash). Turn the adjusting nut ½-turn past this point, giving you optimal pre-load for the rocker arm, pushrod and lifter. According to Newman, “you should look for .030-.060 of preload in a typical hydraulic Lifter.” Follow this procedure by carefully adjusting each intake valve according to cylinder firing order.
            When all of the intake valves have been set to the proper valve lash, you can adjust the exhaust valves. Utilizing the same procedure as with the intake valves, you need to turn the engine over until the intake pushrod moves all the way up and rotates just past maximum lift. Now the exhaust valve can be adjusted. When all of the intake and exhaust valves have been set with the proper lash, it is common for all the top engine builders to perform a double check by rotating the engine and checking each valve again, starting from the first cylinder in the firing order.
            • carls72dart
              365
              194
              Dec 31, 2008
              massachusetts
              View My Photos
              Local Time:
              12:25 PM
              EOIC is the exact procedure I use :)
            • krazykuda
              krazykuda FABO Gold Member FABO Gold Member
              45,407
              10629
              Aug 20, 2007
              Orland Park, IL
              Local Time:
              11:25 AM
              The easy way to find that is to remove the rocker arms and see if the valve tips are all at the same height or are some higher???
              • Agree Agree x 1
              • carls72dart
                365
                194
                Dec 31, 2008
                massachusetts
                View My Photos
                Local Time:
                12:25 PM
                I use EOIC and this is the same information I came across :)
              • carls72dart
                365
                194
                Dec 31, 2008
                massachusetts
                View My Photos
                Local Time:
                12:25 PM
                Should I pull the intake and heads and check from the cam to the rockers? Didn't want to remove the head, if I don't have to! I know if it's a valve problem, the head's coming off.
              • dadodgekid
                518
                138
                Nov 25, 2013
                Palm City , FL
                Local Time:
                12:25 PM
                OK good deal, so we are on the same page.
                • Like Like x 1
                • dadodgekid
                  518
                  138
                  Nov 25, 2013
                  Palm City , FL
                  Local Time:
                  12:25 PM
                  So is Cyl #7 is less compression, is the adjusted bottomed out? or you barely have to screw the adjuster in the rocker to set it? maybe bounced the pushrod out of the cup of the lifter.
                • 4spdragtop
                  4spdragtop FABO Gold Member FABO Gold Member
                  24,712
                  4012
                  Aug 28, 2009
                  Ontario
                  Local Time:
                  11:25 AM
                  Could rocker shaft be bent? Spacer messed up?
                • carls72dart
                  365
                  194
                  Dec 31, 2008
                  massachusetts
                  View My Photos
                  Local Time:
                  12:25 PM
                  Just barely screwing the adjuster in and it sets tight! It is the same for both intake & exhaust.....
                • carls72dart
                  365
                  194
                  Dec 31, 2008
                  massachusetts
                  View My Photos
                  Local Time:
                  12:25 PM
                  Spacers all seem to be positioned correctly... not sure if it's bent...
                • yellow rose
                  yellow rose Doctor of Thinkology.
                  15,415
                  12016
                  Jun 19, 2015
                  Living on the razors edge
                  Local Time:
                  9:25 AM
                  For that tiny cam you can set the preload off the firing order. It's quicker and just as accurate. Unless you have a very long duration, high lift cam.
                  • dadodgekid
                    518
                    138
                    Nov 25, 2013
                    Palm City , FL
                    Local Time:
                    12:25 PM
                    Well if the pushrod is in fact set in the lifter correctly, Im going to guess the hyd lifter is locked up.
                  • JoeSBP
                    JoeSBP RLTW!
                    1,107
                    534
                    Jun 16, 2015
                    NC
                    View My Photos
                    Local Time:
                    12:25 PM
                    so what would be the next step? give it preload, then run seafoam through it?
                  • carls72dart
                    365
                    194
                    Dec 31, 2008
                    massachusetts
                    View My Photos
                    Local Time:
                    12:25 PM
                    I'm going to remove the intake and look every piece over. If I don't come up with anything there, I'll pull the heads.
                    Thank you all for taking the time to answer my questions :)
                  • dadodgekid
                    518
                    138
                    Nov 25, 2013
                    Palm City , FL
                    Local Time:
                    12:25 PM
                    No problem! hope you find the issue!
                    • AJ/FormS
                      AJ/FormS 367 FormS clone 3.09-1.92-1.40-1.09-.78od 3.55s
                      14,867
                      4029
                      Jan 19, 2014
                      South-Central Manitoba,Canada, 900ftelevation
                      View My Photos
                      Local Time:
                      11:25 AM
                      Before All that I would recommend a leak-test on that cylinder with the valves adjusters backed off. Then after I get a number, I would lightly bop the valve stems with plastic tipped mallet; and see if the leakage number changes. If no change but the number is good, like 4 to 8% max. Then I would check the valve stem heights as already mentioned, to be sure that these two are not suddenly sitting higher than the others. And if they are similar to the others then I would swap the rockers over from another cylinder. And if that makes no difference then it has to be hydrolocked lifters. I know it's the long way around to just popping the lifters out and replacing them, but with this rigmarole you know exactly what is wrong-no guessing.
                      I too run a very light preload; 1/2 turn. Yeah they have to be adjusted more often, during the break-in; but after that they go many thousands of miles. Years even. And the payback is no lifter pump-up, and an engine that revs until it floats the valves,or starves for oil on the rods and blows up. But there are fixes for those too.
