[SOLD] Valve Spring Compressor Item #: 67460 Mopar SB
Aspen Racer
Member
Azilda On Canada
Rating - 0%
0   0   0
This valve spring compressor is designed to allow valve spring removal while the cylinder heads are still on the engine. Stud Mount, SB Mopar, Cylinder head on Valve Spring Compressor Material: Steel Fits: Mopar Small Block 318-360, W2 & 3.3 V6 As You know what a chore it can be to remove high-pressure valve springs. Repeat This valve spring compressor is designed to allow valve spring removal while the cylinder heads are still on the engine. Like new. used only once to upgrade valve springs
$150 CDN
Comes with instructions Will ship, Buyer pays Shipping
NO WARRANTY IMPLIED OR GIVEN
I have one of those and they work great. Never had any problems with it.
