valve spring retainers?
Small Block Mopar Engine
  1. 1qwikScamp
    1qwikScamp Well-Known Member
    763
    5
    Aug 22, 2006
    soddy daisy TN
    Local Time:
    5:23 AM
    I have a set of Hughes prepped edelbrock rpm heads I'm upgrading my cam and valve springs to match. My question is how much pressure can I safely put on the factory edelbrock locks and retainers?
  2. Abodybomber
    Abodybomber Breaking street machines , since 1983.....:) Legendary Member
    31,576
    10469
    May 21, 2011
    Arroyo grande ca
    Local Time:
    3:23 AM
    Let's start , with cam installed, and necessary spring specs. Let's start, there.
  3. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    65,845
    39169
    Jun 7, 2010
    Georgia
    Local Time:
    6:23 AM
    I would start with a phone call to Hughes.
  4. BrianT
    BrianT Let's go!
    5,520
    1256
    Mar 13, 2007
    Kansas City, Mo
    Local Time:
    5:23 AM
    When I installed the Comp springs in my Edelbrock's, I had to change the retainers and locks.
  5. 1qwikScamp
    763
    5
    Aug 22, 2006
    soddy daisy TN
    Local Time:
    5:23 AM
    Right now I have the hughes 1111 springs 140#@ 1.800 installed 315# @ .550 lift I'm installing comp cams 914-16
  6. 1qwikScamp
    763
    5
    Aug 22, 2006
    soddy daisy TN
    Local Time:
    5:23 AM
    These are the ones I'm putting on
  7. rumblefish360
    rumblefish360 So close, yet so far away FABO Gold Member
    39,409
    10929
    Jun 21, 2005
    New York, on a Island
    Local Time:
    6:23 AM
    And these work with the Edelbrock retainers?
  8. flyfish
    flyfish C8H18+N2O = :-D
    2,144
    725
    Apr 16, 2007
    Indy
    Local Time:
    6:23 AM
    IDK how strong the stock pieces are, but the matching retainers for those springs are only ~50 bucks...locks are probably 20 ish....so for less than 100 bucks you can have piece of mind. If it were me, I would spend a little more for piece of mind. I'm assuming from the spring you are going with an large ish solid flat tappet cam?
  9. 1qwikScamp
    763
    5
    Aug 22, 2006
    soddy daisy TN
    Local Time:
    5:23 AM
    308 .575 solid roller
  10. 1qwikScamp
    763
    5
    Aug 22, 2006
    soddy daisy TN
    Local Time:
    5:23 AM
    I talked to Jim at Hughes engines and he said that the locks and retainers that they installed on here will take anything I can throw at them. That makes me feel better
