Valve Springs - alternative
Heywodja
The Heartbeat Stops Here
Texas
I am looking at these springs to install on my older grind cam from Hughes. Are there any other sources for same or similar? hoping to save a few bucks..
HUG 1129
DUAL VALVE SPRING
145# @ 1.800" / 358# @ .550" LIFT (PAC SPRING)
$10.00
  • Installed Height/Pressure: 1.800"--145#
  • Pressure @ .550" lift: 358#
  • Pressure @ .600" lift: 375#
  • Pressure @ .650" lift: 400#
  • Pressure @ .700" lift : 425#
  • Coil Bind: @ .750" lift
  • Outer Spring ID/OD: 1.075" /1.459"
  • Inner Spring ID/OD: 1.078" / .794"
  • Type of Spring: Dual
  • Retainers: 5/16" -1278 : 11/32" - 1201
    Spring Rate 391
there are a few companies that make springs. to suggest a spring I ask - what is your : installed height, type of cam, valve lift, spring retainer diameters, spring seat diameters
As noted above they are PAC 1903 springs....
using them with Hughes 6064 cam on two engines
cam specs, will work on getting the rest of the info in next day or so
